New owner 2022 43 Open
I need advice on removing salon door to replace a bad refrigerator.  Anyone have any experience on getting door off?  Unfortunately the fridge is an inch wider than door opening with slide doors fully open.
May need to remove doors???
Did you measure with door removed from refrigerator?
Not sure on your year how to remove slider. If I remember correctly on my older 43 it required removing a pretty large panel that the slider hides behind when in the open position. Not a terrible job but not easy either. I would recommend reaching out to Tiara customer support. They usually have service bulletins for such projects.
(11-04-2024, 09:50 PM)jclark003 Wrote: Did you measure with door removed from refrigerator?
Thanks for the reply.
I took out the drawers and I’m needing another inch or two. From what I could see it’s seems exactly as you stated. Looks like a large panel would need to be removed. It did look doable but would be a project. I was hoping there might be a trick to it.
I sent an email to A contact I have in their customer support. Hopefully they have a tech bulletin that will make it easier. As much as I’d like to replace it, I might be having it fixed inside the salon to avoid the aggravation.
Hello, I’m looking at a number of used 43 Opens and am interested in your experience with regard to forward visibility and noise level underway. Mike S (2006 3600 Open)
  Hello Everyone! I’m a New Tiara Owner! tdeberle@gmail.com 1 236 06-14-2026, 11:44 AM
  [Tiara Open] New Tiara Owner - She's old, but strong jgaudet2 10 4,695 04-23-2026, 02:23 PM
  New Owner Introduction nukey99 14 17,766 04-09-2026, 01:10 PM
Last Post: Capt Steve
  repowering a 27 tiara open mistressfour 3 659 04-04-2026, 08:30 AM
Last Post: Ken Grabowski
  new owner cptnhappy 1 1,346 02-02-2026, 10:51 AM
New owner 2022 43 Open00
