Looking for Help with Fuel Vent Issue - Tiara 2700 (1988)
Hello Everyone,
Filling up my boat with gas is taking a LONG time.  I have to stop every half gallon and let the fuel go down before squeezing the nozzle again. I never heard of fuel vents before but I'm assuming that is the issue .. those two bolts on exterior of boat?  Is that where I should start first?
Are these difficult to replace/clean?  Also is there a hack or workaround to fill the boat up with gas to get me through the weekend until I can order parts and wrestle with this problem?
Thank you very much!
Max
Attached Files Thumbnail(s)
I do not think there is a workaround other than to replacement fuel vent emission filter. It is likely clogged/ or filled with water.
Check the vent screens in the two fittings you circled in your picture. Likely packed full of spider webbing or something similar. Small needle nose pliers or tweezers may help pull some of the gunk out. Doubt that year Tiara has an in line vent filter but if so that would be next on the list to check.
No real safe short cuts.
Thanks guys ... I removed an access panel from the inside. Not a lot of room in there to do much. Appreciate your help!
  [Tiara Open] Unknown noise from Tiara 3800 Open engine room Tony Saitta 4 534 Yesterday, 01:54 PM
  Tiara 40 Express 2003 - Removal of Cleat saywhen 2 377 11-14-2026, 05:25 PM
Last Post: saywhen
  Tiara 52 Sovran Salon Keel Question Knot On Call 2 705 08-17-2026, 05:31 PM
Last Post: Bford100
  Freezer Replacement for 40' Tiara Reprise1 4 1,989 06-09-2026, 02:28 PM
Last Post: fuzzy
Today 08:10 AM
» Replies: 4
Oil Filter ?
Yesterday 04:23 PM
Yesterday 01:54 PM
» Replies: 4
Last Post: saywhen
11-14-2026 05:25 PM
3500 Sovran trimtabs
Last Post: drprunner
11-14-2026 03:44 PM
