Threads: 5
Home Port: NORTHPOINT Marina, Winthrop Harbor IL
Vessel Info: 2006 Cummins QSC’s
I have a 38 Open and want to mount some rod storage racks to my hard top. Has anyone done this and did you use toggle bolts or molly's to hold the screws in?
http://cdn2.bigcommerce.com/n-zfvgw8/ie9...0.1280.jpg
Threads: 30
The cruising Hard Top is hollow and you may be able to use short toggles or mollys. The TTS Hard Top is thinner and foam cored (no hollow space), so you likely will have to use caulk and screws - make sure the caulk is fully dry before you put weight on it.
Threads: 5
Thanks Chris, my top is hollow.
Threads: 5
That top is thicker than I thought. I was able to mount the rod holders right into the fiberglass and the screws had plenty of fiberglass to hold them.
