I have an older 33 open with an ice maker behind the pilot seat in the cockpit. Im sure i am not the only Tiara owner not interested in having an icemaker that uses water from the tank, so I am pulling it. Has anyone seen or created a cool use of this space after removing it. Pictures?
(11-27-2012, 02:59 PM)Steed36 Wrote: I have an older 33 open with an ice maker behind the pilot seat in the cockpit. Im sure i am not the only Tiara owner not interested in having an icemaker that uses water from the tank, so I am pulling it. Has anyone seen or created a cool use of this space after removing it. Pictures?
Steve
I lined the ex icemaker opening with starboard and build storage shelves, made a door of white plexiglass and picked up a ton of new dry storage.
12-04-2014, 09:51 AM (This post was last modified: 12-04-2014, 09:53 AM by Chris Burkard.)
There are some companies that build cabinets that fit in place of the Ice-makers. If you are not handy with fabricating, this may be the way to go. The other option is to replace the ice-maker with a Refrigerator. The Refrigerators tend to be a bit larger than the ice-makers, so you may have to enlarge the hole.
Good Luck!
I guess I should have mentioned this. The company that we used to purchase premade cabinets for Tiaras was Happle. I believe they were out of Miami. I do not know if they are still around, but Tiara used them for OEM, so it should look factory when you are done.
Author's Statistic:
Threads: 14
Likes Given: 0
Likes Received: 2 in 2 posts
Home Port: eastern long island
Vessel Info: 20003 Tiara 38 open
Threads: 14
Likes Given: 0
I have a 33 and put a refrigerator there .works great for beverages.built a cabinet next to it and a outdoor shower above that. Looks like it came from factory that way.bill
Hi Bill, do you happen to have a picture of this?
Steve
(12-05-2014, 05:36 PM)williamwalter Wrote: I have a 33 and put a refrigerator there .works great for beverages.built a cabinet next to it and a outdoor shower above that. Looks like it came from factory that way.bill
dump the icemaker portion (mechanism) and use the box as a freezer only! ... bring your own ice place it in the freezer and you will always have clean ice...yum!
Thats what I did on my 33'....
The following 1 user Likes stones throw's post:1 user Likes stones throw's post Steed36 (10-23-2015)
