Aft Bilge Pump - 2005 Sovran
The Aft Bilge Pump trips the breaker on the main panel almost instantly.    I thought I would start by checking out the pump and float switch.  However it looks to be about a five foot drop between the access hatch in the trunk and the floor of the hull.  I can not even get my hand on it.  Does anyone have any thoughts on access to the pump and switch, or had any experience with this issue?
2005 36 Sovran
Cummings 6C-AT 480
Can you get to the wiring harness going to the pump? If so I would suggest cutting the leads and mounting a new switch and pump on a stainless or aluminum plate.  Attach a handle that can be fastened at the top end. Then wire up the new unit with long leads and drop it in place.  Capt.  George
Captain George, very creative. After viewing your suggestion I did find a Youtube video of a similar design on an S2 sailboat (AKA Slicker)
Let me ask you:
How about using starboard instead of stainless steel for the plate?
I will need to secure it in place and was thinking of just fastening the handle to bulkhead or other structure to keep it in position?
thanks again for your help
2005 36 Sovran
Cummings 6C-AT 480
I made a few using soft aluminum plate as it sets lower and comes on sooner and is easy to bend.. You might also consider PVC sheet, it's much less expensive.  Capt. george
Good point on using the aluminum, and I appreciate your help on this. I will post a reply on the outcome, thanks again.
2005 36 Sovran
Cummings 6C-AT 480
No slack in the wiring harness or in the exit hose. Had to dismantle the trunk lifting arm and remove the covers on the starboard access hatch as well as the center access hatch. this allowed one to lie down in the trunk and work with only one hand to complete the job, took four hours.
2005 36 Sovran
Cummings 6C-AT 480
  Tiara 52 Sovran Salon Keel Question Knot On Call 2 313 08-17-2026, 05:31 PM
Last Post: Bford100
Exclamation [Tiara Sovran] Sunroof motor location on ‘13 sovran 45? Tiara45 0 247 07-28-2026, 06:28 AM
Last Post: Tiara45
  [Tiara Open] 2005 3600 Open / Bait well water deflectors KRB 3 2,553 02-23-2026, 11:01 AM
  Removing Wall Panel on other side of helm on Sovran 3500 no shocks 1 965 02-15-2026, 03:38 PM
  Water if forward bilge after rain lenoah 0 521 11-21-2025, 05:53 PM
Last Post: lenoah
Aft Bilge Pump - 2005 Sovran00
