Replacement TV for 3200 Open
Anyone replace their TV? What's a good one?
I replaced mine on my 2006 36 Sovran with a Jensen.  The ones on the boat were 12 volt so I could not use a standard one form Best Buy.  I got it through Hodges marine.  It fits where the old ones were.  Here is the link.
http://www.hodgesmarine.com/Jensen-Je151...512led.htm
John
36 Sovran, Cummins QSC
I went through the same thing with my 2006 Sovran, but I also learned a little about TV's.  It seems many of today's TV's run on 12 VDC and you can get them at Best Buy.  all you do is look at the specs.  If they are 12vdc, just cut the cord to the power supply and wire into where the old one was!! Biggest problem is, in or around 2006 the TV's for over the air signal switched to Hi Def.  So you either need a new TV that gets hi def, plus an antennae that receives hi-def, or you can use the old ones with a converter.
(06-13-2016, 09:21 AM)johnhesch Wrote: Anyone replace their TV?  What's a good one?
Majestic makes a 12 volt that fits the opening of a 3200 perfectly. No need to do any wood work modification. The company makes cvs for the boating and RV industries.
  [Tiara Open] Unknown noise from Tiara 3800 Open engine room Tony Saitta 2 468 10-05-2026, 11:57 AM
  [Tiara Open] Fireboy FE-241 replacement roboh20 0 460 07-25-2026, 09:15 AM
Last Post: roboh20
  2001 38’ Open interior table base removal twilson0929 3 908 07-07-2026, 08:13 AM
3500 Open deck lift piston
Last Post: drmiagi11
Today 12:51 PM
» Replies: 3
11-04-2026 11:36 AM
