1996 29 open props crusaders
hello:
I have a 1996 29 open it was repowered in 2006 with crusade captains choice 5.7 330hp. the props that are on boat are 17x17. is this the right prop. my top rpm is 4700 to 5000. cruiseing speed is about 20 mph at 3500 rpm. do i have the right props?
thanks
lola
The 5.7 was built in two different horsepower versions. The standard 5.7 was 275 HP and the HO version was 330 HP. If you have the HO version @ 330 HP, the Maximum RPM range is between 4800 and 5200 RPM. If you are reaching 5000 RPM at WOT, then you are smack dab in the middle. According to the Crusader website, you can cruise the engine up to 4000. With all that being said, 17x17s seem too small for your engine package. According to my figures, you should be over-revving with those props.
I pulled an old performance sheet from 2000 for a 2900 Open with 5.7 HOs and Tiara was using 19x22s #7 Cup. The are showing at 3600 RPM, 23.4 MPH. WOT was 4725 RPM, which is a tad low.
I would call a good prop shop and give them all that information and see what they say.
Let us know how it works out.
  38 open bathroom recessed light bulb twilson0929 3 483 08-26-2026, 06:22 AM
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 385 08-18-2026, 02:11 PM
  2001 38’ Open interior table base removal twilson0929 3 763 07-07-2026, 08:13 AM
  1996 33Tiara open - shaft seal lubricant leaking Mydiamond 4 1,399 05-22-2026, 06:41 PM
  [Tiara Open] 2001 3800 Open Holding Tank cap that hold sensor and washdown twilson0929 0 757 05-12-2026, 10:18 AM
1996 29 open props crusaders00
