10-18-2017, 10:30 PM
It's time to replace the duckbill valves in the Vacuum Pump which is attached to a vacuum generator. It appears the vacuum generator and pump are not removable and are inaccessible on the 3900 Sovran. There is insufficient clearance to remove the vacuum generator and the bolts on the vacuum pump are visible but inaccessible. Has anyone got a solution to replacing the duckbill valves on the Dometic vacuum pump? T
