Tiara Open Engine Hatch will not open
2001 Tiara Open
Trying to figure out how to assess why Hatch will not open.  I changed the fuse at the helm and also the switch to go up and down.  (Both purchased at West Marine)
Batteries are good.  What are options to open when there is a problem with hatch?
Any suggestions appreciated.
Reel Vet
If you have an "L lounge" check to make sure the switch is in contact with the lock on the small seat near the front. Good Luck Tom
The small seat your referencing HAS to be removed prior to activating the switch to lift the hatch... There is a "push button" switch below removable small seat that allows the lift switch to work. It's a safety to ensure you remove the small seat prior to trying to lift the hatch.. Switch may have failed....
If the boat has a power helm seat it must be retracted completely
I can not say enough on thanks for the replies. I usually have the seat out of the lounge arrangement most of the time checking engines, generator, etc. I never knew there was a sensor stoping the helm from rising if the seat was in place. I knew the seat had to be out to open to have clearance but did not know it would not open if the seat was in. One of those embarrassing moments. I called Tiara yesterday and they mentioned it may have a sensor but they were not 100% sure on my year 2001 model 3100 Open. I later called the new Tiara dealer in the Annapolis area "North Point" and they confirmed there was probably a sensor so when I checked yesterday and read get the response from the group the problem has been resolve. I will keep the new fuse in and switch.
Thanks again,
Reel Vet
Annapoli, Md
[-] The following 1 user Likes IrvingVet's post:
sluggo (09-12-2018)
  38 open bathroom recessed light bulb twilson0929 3 230 08-26-2026, 06:22 AM
  [Tiara Sovran] Main engine hatch gas shock lift assist bracket separation hmtrerice 0 180 08-21-2026, 02:33 PM
Last Post: hmtrerice
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 285 08-18-2026, 02:11 PM
  2001 38’ Open interior table base removal twilson0929 3 612 07-07-2026, 08:13 AM
  1996 33Tiara open - shaft seal lubricant leaking Mydiamond 4 1,253 05-22-2026, 06:41 PM
Engine Hatch will not open00
