Tiara Open Cockpit circuit breaker removal.
In the cockpit at the shorepower inlets, there are two circuit breakers. I need to replace the 30 amp breaker. I removed the 4 screws and loosened the "bolt" but the small panel won't pull away. How do I access? Do I have to remove the entire step?
My guess silicon or even 5200 is holding the plate in place after screw removal. Try prying behind the plate w/circuit breaker.. Be careful not to crack the plate or breaker. M2C
Use a paint scraper to work behind the plate ans loosen whatever someone put on it. Make damn sure the power is OFF! If that scraper slips behind and connects to a power wire all hell is gonna break lose.
(04-30-2019, 05:42 PM)Sans Peur Wrote: Use a paint scraper to work behind the plate ans loosen whatever someone put on it. Make damn sure the power is OFF! If that scraper slips behind and connects to a power wire all hell is gonna break lose.
Thank you, Sans Peur and Captain for your replies. I used a serrated thin steak knife ( thank you, my wife) and a mallet and was able to remove the plate without damage to myself or the vessel though the knife may never be the same again!!
  [Tiara Open] Main DC Breaker for 1995 Tiara 36 Open petrienorris@gmail.com 2 1,026 07-15-2026, 08:06 AM
  Electric Breaker panel Jbuchsdvm 5 4,847 10-21-2024, 10:08 AM
  [Tiara Open] Push button breaker 12v replacement Mydiamond 2 1,601 09-28-2024, 09:01 AM
  2000 3500 Express Cockpit Fridge and Plug Outlet Breaker Location JMGCINCY2023 2 1,605 08-18-2024, 07:22 PM
  1994 43 Open Cockpit Courtesy Light Fixtures carbon20 1 2,042 11-12-2023, 11:37 AM
Last Post: Afarneti
Cockpit circuit breaker removal.00
