Erratic DC Power Loss 40 Express
Looking some help….
Today was the first day we took our new-to-us 40 Express Out.
When we were ready to leave our anchorage, went to start up the mains.  Systems powered up but engines would not start.   Not even a click.   Went to start genny, same issue.
Started checking a few basic things….only known issue that came up from survey was a faulty voltage regulator on the house bank charging engine; tempary fix is to inter connect the battery banks to make sure both are charging under way.
So back to my issue….after checking some things- When I shut off the DC Main breaker on the DC panel in the salon I can start the main engines.   When the panel is on issue re-turns.   On the genny there was a red on/off switch that was in the off position (I am assuming it’s a breaker switch that tripped).
This was the order of operations:
At dock prior to leaving, started genny, then mains, then disconnected shore power.  Spent a few hours on the hook but shut down genny about an 1 hour before we decided to leave.    That is when we discovered that we couldn’t start the mains without shutting of the main DC panel switch on the main DC panel.
Anyone have some insight here that they could share?     I can understand weak voltage being a possible culprit but that DC switch issue is just not making sense as it is on but nothing is drawing a load on the DC side….
Well I found the issue but want to share the results because while my issue is fixed the result is bizarre.  On the DC main panel there is a breaker labeled HELM and it must be in the off position to start the main engines or work the hydraulics.   Super bizarre but also is it genius?  As in its a way of killing the power so no one can open the trunk or start the engines without having access to the cabin?
(09-12-2020, 03:10 PM)August Rush Wrote: Looking some help….
Started checking a few basic things….only known issue that came up from survey was a faulty voltage regulator on the house bank charging engine; temporary fix is to inter connect the battery banks to make sure both are charging under way.
I would say it is exactly for what you think. There had to be a way to keep someone from just opening up the back and gaining access.
  1997 4000 express shore power issue Salty0ne 10 4,352 03-31-2025, 08:27 PM
  Main Panel Switch needed or 1997 40 mid cabin express Salty0ne 0 828 03-28-2025, 09:44 PM
Last Post: Salty0ne
  2000 3500 Express Cockpit Fridge and Plug Outlet Breaker Location JMGCINCY2023 2 1,687 08-18-2024, 07:22 PM
  Fridge and freezer isotherm combo only work with shore power or genset Toyoda 2 3,015 07-26-2023, 03:55 PM
Last Post: Sapphire
  No power to dash Mydiamond 5 4,465 05-07-2023, 07:52 PM
3500 Open deck lift piston
Last Post: drmiagi11
Today 12:51 PM
» Replies: 3
11-04-2026 11:36 AM
