%%TYL_NUMTHANKEDLIKED%%
Threads: 2
0
Home Port: Long Island sound
Vessel Info: 29 coronet
04-01-2021, 03:30 PM
(This post was last modified: 04-01-2021, 03:31 PM by ctkite.)
The guy pulled the risers elbows and the like ... said it took 40 hours labor @ 125 per hr. I figured a long day a side if I did it myself and im not a pro. anyone do this and can give me a idea if this is crazy . TIA
98 coronet xli's
Threads: 8
0
Home Port: Pompano Beach, Fl.
Vessel Info: 1999 2900 Coronet, 7.4 mpi Crusaders
Hi,
Unless there were a whole lot of issues, $5,000 is crazy.
I did mine as you said, one day per engine. You should have a discussion and a break down of the costs. You'll be doing this again in 4years if you're in the salt and you need to understand what went wrong.
Regards,
Paul
Threads: 45
2
Home Port: Long Island Sound
Vessel Info: 3100 Open, 2002 Model Year, 8.1L Crusaders
I did my own and I bet I could have done them both in one long day. 2 days tops. Unless they pulled all of the exhaust hoses and exhaust elbows and inspected them all. But even then it is only another 4-5 hours.
Threads: 3
0
Home Port: Pensacola, FL
Vessel Info: 1986 3600 Continental
454 Crusaders, 350hp, (Carbureted)
7.5kw Diesel genset
I did mine in about 8 - 10 hours per side on my old school Crusader 7.4Ls. They had not been replaced in at least 10 years and I changed the 30 year old manifolds while I was at it. You are getting fed a line of........
The important thing is to retorque everything again at 5, 10, and 20 operating hours. It was surprising how much more they tightened up at 5 and 10 hours. After 20 hours I haven't found they took anymore torque.
Rob
Threads: 1
0
Home Port: Newport Beach, California
Vessel Info: 1989 Tiara Express/Open. Crusader 454
We had the local mechanic who seems to have a good reputation around our yacht club recommend replacement of the Risers and Elbows- We have a quote for $4,950 including all parts and labor -- The boat is new to us but have known that the past two owners have not replaced them in at least 10 years. I will upload the invoice once its completes. -- Note the parts were over $2k
Threads: 2
0
Home Port: Clear Lake/Galveston Texas
Vessel Info: Currently looking to purchase my first Tiara
I was recently quoted $400.00 per side by my local mechanic. That included replacing manifolds, risers, elbows and exhaust tubes. 5K is nuts!
