Tiara Open 1984 Tiara (Pursuit Hull ID?) open one engine cuts off when put in gear
First of all thanks to all that read this. My nephew has purchased a 1984 Tiara 3100 open for his dream boat. He purchased it in Daytona, Florida and is trying to get the boat to Destin, Florida via water. He has had a few setbacks to say the least. Broken belts, replaced impeller, ran into a sand bar and $1100 prop repairs. His current problem is both engines crank and run fine but as soon as he puts one engine in gear an alarm sounds and the engine dies. Any thoughts? I am trying to help him out as much as possible, but I haven't seen the boat yet and can't find any documentation on the boat at all. Does it have a diagnostic port and is it carbureted of fuel injected? I have written Tiara and they have told me that the hull id is a Pursuit model and Tiara sold off that brand. I sent Pursuit an email but no answer from them so far. Any help would be appreciated.
A boat of that vintage likely has carburetors and no diagnostic port. The engine alarm goes off for one of three reasons. Oil pressure, transmission temp, engine temp.
Does the alarm go off right when it stalls? That could simply be the loss of oil pressure when it stalls.
I'd be concerned about the hitting of the sand bar. If the props were damaged, what else was? Did it suck sand up thru the raw water side of the cooling and is that now plugged up?
Was it running properly before the sand bar was hit?
As misdirection said I would bet the cooling system from the strainers to the oil coolers and heat exchanger are probably full of sand. Strange that tiara won't help you out as even though it's technically a pursuit it was the same company then.
Do you know what alarm is going off? I had a problem with one shutting off like that but no alarm. I connected both neutral safety wires to one contact, eliminating the switch but I also took apart the big harness plug near the trans and cleaned all the prongs. It fixed it. So I changed out the neutral safety switch just in case it was that. So my problem was one of those 2.
Sorry for ignoring this post for so long, for some reason I never saw a reply. As it turned out he had tied up yo a fishing pier overnight (kind of an emergency pitstop) and when he got ready to leave he apparently hit a rope of some kind and it wrapped around the prop. I am a little surprised that was the problem but better than breaking something else. Thanks for all of the comments!
  2000 3500 Open - Engine Sync Switch (7.4 MPI's) BIG_D 5 2,055 08-14-2026, 05:33 AM
  '93 TIARA 2900 OPEN ENGINE OVERHEAT WITH COOLANT/WATER POSSIBLY MIXED WITH OIL Showtime 3 2,022 05-23-2026, 02:12 PM
Last Post: Capt. Paul
  [Tiara Open] Repowering a 1992 3300 Open WOLFDAWG71 1 1,296 02-17-2026, 06:46 AM
  Engine shut off while running Mydiamond 1 1,031 08-10-2025, 07:51 PM
  [Tiara Open] 2900 open - 454 mounts North000 0 674 06-12-2025, 08:21 PM
Last Post: North000
Site Update 10/23/2026
Last Post: YOLO
Yesterday 10:56 AM
Last Post: and220
10-20-2026 05:46 PM
Full Camper Back for Tiara 39 Sovran
Last Post: mws59@aol.com
10-18-2026 09:56 AM
10-14-2026 07:47 PM
3300 New Service Provider
Last Post: Boatworks
10-14-2026 02:09 PM
