2004 3100 Alternator
I am the owner of a beloved Tiara 3100 Open.  I have had alternator problems and fount that one of the boards in the Charles external voltage regulator was bad.  I replaced the alternator with an internally regulated one and I don't know how to wire it properly bypassing the external regulator.  Can anyone help me.
Happy boating & thanks.
You remove the wiring between the regulator and the alternator. From the factory this would have been a small (14AWG) blue wire and a small (14AWG) yellow wire. Sometimes there was temperature sensor installed on the alternator as well--this can be removed as it will no longer have any function. Essentially just connect the large ground conductor and large positive conductor to the new alternator.
The only other point to make is that some internally regulated alternators are not self-exciting. If your new alternator needs external excitation, this would be a new wire run from the ignition to the alternator (you could use the purple wire previously used to power the regulator). If you're not sure if the new alternator is externally excited, just try it without this connection, you won't hurt anything.
Hi Hiccup,
Thank you! I think this is what I need.
Happy boating!
  [Tiara Open] 93 3100 fuel tank sending unit. Joeboch348 1 667 02-18-2026, 09:15 PM
  [Tiara Open] 1989 3100 Open Wiper Arm Removal mmcintee1985@gmail.com 10 3,365 11-24-2025, 09:21 PM
  [Tiara Open] Need Source for Scuppers, 1995 3100 E-MAN 2 979 09-02-2025, 10:31 PM
Last Post: E-MAN
  2001 Tiara 3100 Open wipers IrvingVet 4 5,862 08-23-2025, 01:32 PM
Last Post: nylakeshome
  Replacing fuel full hose 3100 Open Joeboch348 1 1,080 08-20-2025, 03:53 PM
Last Post: S4Survivor
Yesterday 11:36 AM
89 3100 convertable
10-30-2026 06:13 PM
