LED Cabin Lighting
Have a 1999 35 Open, the cabin has many 3" halogen lights and they run very hot.  Would like to replace with led lighting to reduce the heat given off by halogens.
Does anyone have a good supplier or can recommend a bright led light?
Kent
Kent
1999 Tiara 35 Open, Cummins
(01-17-2015, 08:21 AM)torchlake99 Wrote: Have a 1999 35 Open, the cabin has many 3" halogen lights and they run very hot.  Would like to replace with led lighting to reduce the heat given off by halogens.
Kent
You looking to replace fixtures or buy bulbs
Kurt
Looking to remove the old 3" pucks and install new lights.
thanks
Kent
Kent
(01-17-2015, 08:53 AM)torchlake99 Wrote: Looking to remove the old 3" pucks and install new lights.
thanks
Kent
I just replaced bulbs in the cabin and the running lights. It cut the amp draw down almost 5 amps. Love them.
What bulb did you replace them with?  Must have been something other than a halogen.....
Kent
(01-17-2015, 10:44 AM)torchlake99 Wrote: What bulb did you replace them with?  Must have been something other than a halogen.....
Replaced them with LED bulbs from Marinebeam.com. They are located in South Carolina. They were very helpful. I am extremely happy with them. Replaced the running and anchor bulbs also. A little pricey but worth it because they dont draw the amps when on the hook. Looking to replace the florescent tubes in the cabin next. Those are quite pricy though.
Kurt
Thanks Kurt, I was also going to replace those cabin fluorescents.  Was thinking about led strip lighting as an option.
Kent
Kent
Which LED replacement did you buy at MarineBeam?   Any trouble installing?
(01-18-2015, 06:47 PM)DavidB Wrote: Which LED replacement did you buy at MarineBeam?   Any trouble installing?
Take whatever bulbs you want to replace out, then call them and they can tell by your description which bulbs you need. They can also help with the color and the watts. Take notice of how much clearance you have between the bulb and your lens also. LEDs don't produce a lot of heat so that is good also. They also have deals on quantities. Easy to install and you will love the light and reduced watt draw on your batteries. You are talking about 12 volt lights I assume.
Yes 12 volt.  Thanks, this will be a good winter project
Kent
  [Tiara Open] Cabin light bulb replacement Bbarroll 2 3,119 06-06-2025, 03:57 PM
Last Post: Joe.dammann
  Main Panel Switch needed or 1997 40 mid cabin express Salty0ne 0 874 03-28-2025, 09:44 PM
Last Post: Salty0ne
  LED Lighting Upgrade 3100 Open TWO SUNS 2 6,839 07-11-2024, 02:07 AM
Last Post: Pop Alexandra
  [Tiara Sovran] Replacement Bulb / Cockpit lighting. Euphoria38 4 4,296 06-09-2021, 02:33 PM
Last Post: Euphoria38
  Tiara 4000 Mid Cabin Express - Inverter location? SteveC 2 3,377 04-21-2020, 03:49 PM
Last Post: SteveC
