Disappointment
I joined shortly after buying a 2005 Tiara 2900 I joined thinking that it would help me get to know my boat especially the many things that are not covered in the owners manual. I have written a couple of posts about things that one of the many owners would know about. I get nothing back and in fact get more responses from non-specific boating sites. I will probably withdraw from this site if things do not improve.
(04-05-2015, 07:39 PM)Russf Wrote: I joined shortly after buying a 2005 Tiara 2900 I joined thinking that it would help me get to know my boat especially the many things that are not covered in the owners manual. I have written a couple of posts about things that one of the many owners would know about. I get nothing back and in fact get more responses from non-specific boating sites. I will probably withdraw from this site if things do not improve.
You have 9 posts and have only been a member for 3-4 months. Your disappointed because nobody answers your questions which I assume are specific to your boat? Is that correct? I read your questions about the covered switches and if you had a photo it may have helped because your description was not that great.
Your post suggests that only after I have been a member for a good while and have made a lot of posts that I would get some help. Thea/c panel post was quite clear. If you have a 2005 2900 you will likely see two protected switches. One is marked the other is not. What does the unmarked one do was may question.
Russ,
Check over in the 'Open' forum and you'll find a (hopefully helpful) reply to your post.  If my first reply doesn't solve your problem, we'll keep trying.
Patience is a virtue, my friend.
All the best,
Mike
Fiddlehead
Getting your question in the correct thread is a big help don't give up on us as I see you are getting replies
Russf,
I can answer most questions about your boat. E-mail me directly (see below). When I get busy, I don't have time to check the posts here very often.
