Mid Bilge Bulkhead
Need some help from the Tiara heads:
The mid bilge on my 98 31 open has been wet for a few years (slow drip form my PSS or strainers I believe) and hasn't been much of a problem. It seems though that the mid bilge forward bulkhead has absorbed a good bit of water and rotted internally.  So as a good boater, I'm planning on drilling out the rot and glassing it up (inside and out).  I drilled  a few holes to help the dry out process and was about to mix the resin when I dug around and got totally confused.
The Mid bilge forward bulkhead has a wide lumber hole leading forward to another bulkhead about 1" or 2" behind (forward) of it.  I can't see if this bulkhead is open to the forward bilge (higher) and no light passes through from the forward area, so why is there a lumber hole?  Can I fill it all in and strengthen the whole area?  Am I missing something linking the forward and mid bilge?
Wanted to ask the group before I started glassing up something that should be open for safety?
Any help or guidance would be appreciated!
  Water if forward bilge after rain lenoah 0 702 11-21-2025, 05:53 PM
Last Post: lenoah
  Keel bilge pump runs on 52 Sovran Salon during trips Knot On Call 9 3,194 08-21-2025, 08:28 PM
  43 open keel bilge vs mid bilge bnr@dur-a-flex.com 2 1,664 12-08-2024, 07:34 AM
Last Post: bnr@dur-a-flex.com
  [Tiara Open] Forward bilge wiring Mydiamond 1 1,277 09-19-2024, 11:54 AM
Last Post: ardoski14
  50/53 Coupe and Fly Owners Group-Rain Water in Bilge Sapphire 3 2,202 02-11-2024, 09:53 AM
