Noise Level at Cruise
New member to the site - hopefully soon to be a Tiara owner.
We have a Grady White 330 Express with twin 4 stroke Yamaha's and are wanting to move up to the Tiara 3800 Open (or larger). We do a lot of cruising (live near Tampa, FL and run our Grady down to the Keys and down/over to the Bahamas several times a year). Also fish/dive a lot, thus the focus on the Open rather than the other Tiara models.
We have been on several boats at boat shows (looking used in the 2003 - 2006 era) and are satisfied that making this upgrade to a larger twin diesel inboard boat will work for our needs/uses.
But, the one concern that I have, is the noise level at the helm while underway. With the 4 stoke outboards, the predominant noise we have is wind rather than "engines/mechanical" while underway. The only diesel express that I have been on recently is a buddy's 3400 Pursuit with twin cummins (don't know what model) and it is quite loud while running.
Can anyone here give me some input / advice / real life feedback if you made a similar switch from outboards to inboard diesels? As much as I want to move forward with the upgrade, I would hate to find out we don't use the Tiara as much as we used the Grady due to the fatigue factor from running it.
Thanks to everyone for their help and input.
Jim
I currently own a 2003 38 Open w/450 Cummins and cruise quite a bit..... The noise at the helm station at cruise, 2100RPM/24knots, is acceptable in my mind although I don't believe its as quiet as you indicated for the Grady w/twin outboards. Typical cruise duration is about 3-5 hrs...... Ran several other non Tiara's and the noise at the helm station seems the same or higher than on my Tiara........ M2C
We have a 35 Open with the Cummins diesels.  Couple of factors can make a large difference in the noise levels. Our boat has the helm that lifts up  via two hydraulic cylinders,  there is a dense foam strip that has been placed between the two so that when closed it seals off the union.  If there breaks in this foam strip it will greatly increase the noise levels so make sure the foam is in place and good working order.   Even with this in good working order we wanted to reduce the noise level and carpeted the helm area.  Chose a outdoor carpet with a thick dense pad attached to the back of it.  Made a template of the area to cover and had it bound on the edges.  It has made a significant difference to the level of sound as it covers the small hatch to the engine room and the hinged area forward on the helm.  We are happy with the difference.
Kent
1999 Tiara 35 Open, Cummins
(04-26-2015, 05:03 PM)alfa1023 Wrote: New member to the site - hopefully soon to be a Tiara owner.
Jim
Hi Jim,
Last year I sold my 29' Wellcraft Coastal that has twin Yamaha F250s that we loved for many reasons but especially because it was so quiet.  I also had concerns about moving to an express with engines directly under the helm area because I was used to the "silent ride".  I tested a 3200 open with gas motors and found that at cruise I didnt like the sound level (higher rev at cruise than diesel) it was too loud for me based on what I had gotten used to.  I then tested and bought a 2008 3200 open with Cummins diesels.  This boat is surprisingly quiet at cruise and around the dock. Still louder than the 4stroke outboards but a lower tone and at cruise (2500 rpm vs gas inboard 4000 rpm ish) it was a fine transition for us.   Look for electronic controlled common rail diesels as they are much quieter than their predecessors.
Mike
I used to have a 34 Pursuit with Cummins 370's.....at cruise ....2400 rpm 24 knots...I thought it was pretty loud.  I now have a 2002 Tiara 38 Open with the 450 Cummins and it is quieter than the Pursuit.  But I still limit my running time to 3 to 4 hours.  If I am at the helm seat and my wife is in the L seating, it's difficult to have a normal conversation at 23 knots.
I have a 2006 42 Open that my wife and I can talk while running normal cruise at 1980 RPM and 28 knots. Yes we probably raise our voice a little but certainly not much. After delivery (new) I surprised my wife adding helm air. My wife says that is one of the best things I ever did, lower noise level and overall comfort. We cruise and find even after a six hour run the exhaustion factor is minimal. 42 Open is equipped with Cummins QSM 11. 660HP. Love the boat!
Thanks to everyone for their comments and information. We are going to look at a 42 Open and a 38 Open (both close to us at Galati in St Petersburg, Fl). The 38 has Cats and the 42 has Cummins. Not sure if we can/will do a sea trial, but hopefully we can start them at the dock to get a feel for noise/vibration at idle.
We just did a 4 day, 250 mile round trip with our Grady so we hopefully will still have fresh on our minds a proper comparison.
Jim
Well we didn't get to start the engines, much less do a sea trial (not that I was expecting one) on either of these boats.
We are starting to get concerned that we will not have any way to find out if we can live with the sound/vibration levels of the diesels without going all the way to putting a contract on a boat and doing a sea trial. But that makes no sense for either the seller, broker(s) or us.
I know this sounds crazy, but is there anybody in the Tampa Bay area that has a 38 or 42 open that would be interested in going for an "all expenses paid" boat ride? By that I mean I would gladly pay your gas and whatever other costs you had to run the boat, as well as gladly buy you lunch/dinner someplace if my wife and I could pick your brains about your boat. I promise we are normal people (ok, as normal as boat owners can be) with no criminal record, no bank accounts in Nigeria, and probably can't find the middle east on a map.
Thanks for all of your help,
Jim
Hello Jim.
I went through the same thing when buying. Sold a 335 Pursuit and bought a 36 open Tiara. I would have paid someone to bring me for a ride to see what I was getting into. At any rate I did it, very pleased with my decision. Mine is not the same as you are looking at but if I can answer any questions I'll be glad to help. I'm in Clearwater. My neighbor just sold a 38 open, I've been out on it 6 times so I have a little feel for that boat. Some of your questions will have longer answer than I type and will lead to other questions. Like I said glad to share what I've found out if you are interested.
D.
If you decide the 42 Open is a candidate, contact me, I have a very nice 2007 I am considering selling. Jim Gilly
  Access to the starboard fuel level gauge sensor? Tom Stewart 0 840 04-19-2026, 08:21 AM
Last Post: Tom Stewart
  Cruise speed- 2900 Open DEG228 3 3,050 07-29-2025, 04:21 PM
Last Post: DEG228
