New 1982 Tiara Pursuit 2700 Owner!
Hello Everyone! My family and I owned a 1969 23 foot slickcraft since 1989 and recently upgraded to a 1982 Tiara Pursuit 2700. Boat is making its way to the slip very soon here in Chicago - cant wait to get out on the open water and enjoy it!! Have a question though regarding the heat exchanger - does anyone know if they can be flushed and what is the proper way to do it? We've had a couple of issues with the port and starboard engines running a little hotter than normal on its attempt to get back here from the storage yard. This boat just sat and wasnt that well maintained before we bought her this spring and needs some TLC and we're ready for that. Engines received complete tune ups. Already have replaced impellers and thermostats and impeller shaft seal. Any tips, comments, or suggestions are appreciated. Thanks! FishOn
I cleaned my heat exchangers by removing them and flushing them with diluted swimming pool acid. Worked great. Then I installled new gaskets and zincs. There is a product called Barnacle Buster that I have not tried. Check into it. You may also need new elbows and risers if they are over 5 years old.. Be sure to use the correct gaskets and blocking plate. On my 454's I used the one water hole gasket on the elbows and installed it at the top. The three hole gaskets go at the manifold.
Capt. George
  [Tiara Sovran] New Member and 3500 Owner in Stuart Fl LastDance 2 1,492 10-11-2026, 11:11 AM
Last Post: drprunner
  [Tiara Open] Just got my 2006 Tiara 2900 for Chicago Lake Michigan MyTime 1 663 09-05-2026, 03:20 PM
Last Post: JLRedfish
  New owner of 1994 4000 Express Harvey29902 1 735 07-14-2026, 07:48 PM
Last Post: Raberger
  Looking to be a new owner soon Brock71 0 627 07-08-2026, 02:54 PM
Last Post: Brock71
  Hello Everyone! I’m a New Tiara Owner! tdeberle@gmail.com 1 662 06-14-2026, 11:44 AM
Users browsing this thread: 6 Guest(s)
