Cockpit table
    After much thought, design and a little hemming & hawing, I finally solved the issue of getting a stable, removable table in the cockpit of my 98 1 Open.
In reality not as hard as i thought!  Maybe a little pricier, but well worth it!
Table top is Eude ordered from Defender ($235)
Column and Base NorSap 900mm (non stock Order $198) - love the base, no post hole, only through bolts, twist lock to tighten
Custom welded removable central lateral brace with fixed base and chrome plating ($15 steel - $90 plating)
Edson Marine Radar arch collar ($48)
Chrome bolts, nylon washers SS screws ($12 or so)
I finally realized that the plywood base of the setee is a perfect attachment point.  Three 4" ss #12 screws and she's locked tight.
Nice job, looks great!  Question, the brace that comes off the L lounge table when the table comes off does that brace drop down or do you take off the brace from the lounge?  Thanks  Kent
Kent
1999 Tiara 35 Open, Cummins
The bracket is actually 3 pieces.
1)  A Fixed Base plate that is screwed to the Seatee base (3 - #12 4" SS screws - with angled nylon spacer to accommodate the angle of the seatee base).
2)  Removable Bracket - bolts to the Fixed plate (i welded bolts to the back of the plate, but it could also be threaded (4 - 3/8" x 1/2" Chrome hex head bolts)
3)  Edson Marine Radar Arch Collar (note the collar is 2 3/8" diam. and the post is 2" diam. - i cut a rubber pipe coupling from Home Depot to fit and it perfectly fills the gap)
The bracket and Collar can be removed with a hex wrench leaving the fixed base hidden under the seat overhang.  The post is removable as well leaving the simple 10mm base plate.  Clean and simple!.
Hope this helps.
Beautiful job!  Well done.  Going to show my wife and see if she would like the table.
thanks
Kent
Kent
Thanks Kent!  If  she give you the "GO", i can give you dimension and or the other spces.  It does really make the cockpit and seatee more usable, I hated having to have a plate on my lap every time we ate!
I've got a few more projects to add, so ??  Careful, you might have a busy winter!
Well boat is in storage and I have several projects for the winter, your table being one of them.  Any additional information you can send me please do.  kentrabish@gmail.com
Also I am wondering if the  same table you build for the helm are could also be set up for use in the cockpit?  I could see the use of a table that is movable for use in the two areas and when not in use just stored away.  Looks like you design goes up and down easily....
thanks
Kent
Kent
Very nice.  Do you have a part number or supplier on the Edson shaft collar by chance?  I cannot find it on their website.
Dave
Hey Dave
The Edison Part no is 998-23: mounting clamp for 2 3/8" pole ($52). I believe I believe I ordered it directly from Edison, but any re-seller should be able to get it (West Marine or Defender).
I also used the rubber collar from a pipe connector to make up for the 3/16" or so difference in the column diameter. Got it a Home Depot. Just cut it to fit.
Cheers - post some pics when you get it done!
  [Tiara Open] '86 3600 Open Cockpit Deck Hooper 2 2,191 12-10-2024, 10:57 AM
Last Post: Hooper
  [Tiara Open] Cockpit - Adding a table tglass 3 2,670 09-28-2024, 01:17 PM
  2000 3500 Express Add a Cockpit Table JMGCINCY2023 0 1,018 08-04-2024, 06:58 PM
  Pedestal Table for 31' Open? RCKLAW 7 8,478 06-27-2020, 07:50 AM
Last Post: RCKLAW
  [Tiara Open] My Cockpit Table Project! efontana 5 7,441 05-04-2020, 09:59 AM
Last Post: efontana
