A/C & Refridgerator Condensate '06 3000 Open
Seeing a small amount of water in the bilge and can't find the source. Could it be the A/C or Refrigerator condensation being drained into the bilge? Or, do these boats Venturi into the raw water discharge. Thanks
Both my A/C units drain their condensation into the bilge.
Capt. George
(09-01-2015, 08:26 PM)Uhehner Wrote: Both my A/C units drain their condensation into the bilge.
Capt. George
Thanks for the reply
On my 2003 38 Open the Air Conditioners (have 2 units) drain into the shower sump pump. Don't know about the refrigerator or even if it has a condensation drain.
(09-02-2015, 06:01 AM)ReelMagic Wrote: On my 2003 38 Open the Air Conditioners (have 2 units) drain into the shower sump pump. Don't know about the refrigerator or even if it has a condensation drain.
It appears that my boat drains into the shower sump as well.  Thank you for the observation and reply.
(09-01-2015, 05:53 PM)The Kook Abides Wrote: Seeing a small amount of water in the bilge and can't find the source. Could it be the A/C or Refrigerator condensation being drained into the bilge? Or, do these boats Venturi into the raw water discharge.  Thanks
My 2002 38 also has both A/C units draining into the shower sump.
Most Tiaras will drain the condensate into the shower sump. As for mysterious water in the bilge, you may have a leak. I have seen all kinds of leaks over the years from fresh water tank leaks, to hose leaks to cracked barb fittings and loose hose clamps. figure out if it is fresh or salt and go from there.
Good Luck!
  2900 open - a/c water pump not running North000 2 1,845 06-22-2025, 02:18 PM
  New AC install on 1985 3100 open CaptChris2334 1 2,613 03-30-2024, 01:25 PM
  41 Open AC water pump vapor lock esf 3 2,487 08-07-2023, 04:07 PM
Last Post: esf
  1993 4300 open waste and water level indicators bpro 1 3,345 08-07-2023, 08:31 AM
Last Post: esf
  03' 38 open helm air vent P/N? jmm 3 2,964 03-05-2023, 06:44 AM
