New Member
Hi,
my name is Steve and am looking to get a used Tiara 3100 Open. I have been doing some research on the Hull Truth and am here to learn more.
Where are the fishboxes and livewell located in the 3100 Open. I've looked at a few of them but none of them had these. Also I've read that some of you have icemakers. Is this an aftermarket item? Any pics?
On my "88 31 Open the fishbox was under the large hatch in the rear center of the deck. It had a drain line from the bottom center and out the transom. The Stbd. rear hatch had a live well fed by a pump under the fishbox. I did not have an icemaker but I did see some mounted under the Stbd. seat. Why would you put stinky ice cubes made from old water tank water in a fresh drink? Some day the icemaker manufacturer will build a unit with its own bottled water supply tank. I only use water tank water for washing. I buy fresh ice cubes and keep them in the cooler or freezer. Capt. George
  [Tiara Sovran] New Member and 3500 Owner in Stuart Fl LastDance 2 1,511 10-11-2026, 11:11 AM
Last Post: drprunner
  New Member To The Forum OGDash 0 445 08-01-2026, 11:52 AM
Last Post: OGDash
  new member kps@dundee.net 0 648 06-21-2026, 08:33 AM
Last Post: kps@dundee.net
  [Tiara Open] new member john122557@msn.com 0 808 07-30-2024, 10:53 AM
Last Post: john122557@msn.com
  [Tiara Open] New forum member - Northern Chesapeake Bay cmgtrumpet 1 1,100 07-03-2024, 01:52 PM
Last Post: Donaldjames
