VHF / cable switch location
Hi, I can't for the life of me, locate this switch on my '04 38 open? Any help would be very appreciated. Thanks and regards dave
In my 2003 Open 35 it is below the AC panel in the compartment on the right side wall.
Hope this helps.
Richard
Thanks Richard- no luck, I've been all over this boat an am stumped! Thanks for your response regards dave
Vhf antenna cables are usually not very long. Therefore I would trace back down the antenna cable from where it comes into the helm area and look for a white 1/4" diameter cable with a PL259 connector on it. It will probably go into a small box with two other PL259 connectors and red and black 12 volt supply leads. The other two white cables will go to your radios. This would be for an automatic switch, not a manual one. A manual switch would not have 12 volts connected to it and would be in a location where you could see it and operate it. Good luck. Capt. George
The switch was located, on my 38 Open, in the storage bin area at the top right of the closet; open the stateroom closet door, on the top right is a small storage area; my switch was located in that storage area.
Nope not there either, mine is a B plan boat- this is crazy, where the heck is that is that little thing hidding :bang:
My switch on the 40 express is located in side behind the a/c d/c master panel . Open up the panel and look back there . Just a long shot . Good Luck .
nope, not on or near the panel, thanks for the suggestion though. Any 38 open B plan owners out there. Still looking
Found it!!!! thanks for all those who helped with suggestions, regards dave
I have to know where was it?!?!?!
Big Grin
1999 4300 Convertible
  3100 air conditioner location? waggles02673 5 5,836 09-24-2022, 01:46 PM
Last Post: rafredrickson
  Shift cable on a 3100 Open Matta0413 3 4,136 11-30-2019, 05:08 PM
Last Post: justrollin
  Fuse location electric head Cgarst 1 3,796 08-13-2012, 12:32 PM
Last Post: Uhehner
  Fuse location electric head Cgarst 0 2,516 08-12-2012, 04:05 PM
Last Post: Cgarst
