Fresh Water Pump 2001 3100 Open
Hi,
I lost water pressure today to all of our fresh water (sink, toilet, shower) and have been looking for the pump most of the day with no luck. I have a feeling it is located on the firewall behind the water maker (see the photo) but don't want to remove the water maker if this is not the location. Anyone have an idea of where the pump may be?
Appreciate the help and suggestions.
Thanks,
Eric
I could not open your photo but my guess would be to locate the water strainer that goes between the tank and the pump. It should be clear plastic, round, about 3" in diameter and readily accessible for cleaning. Then follow this hose to the pump which should be nearby. Also check your owners manual, there is usually a diagram showing item locations. Hope this helps.  Capt. George
Thanks, found it under the water maker...easy fix, new pump and all is well. Thanks!
  89 3100 convertable kps@dundee.net 1 1,116 10-30-2026, 06:13 PM
  39 Sovran VacuFlush Pump Access Euphoria38 6 3,284 07-26-2026, 10:26 AM
Last Post: Euphoria38
  [Tiara Open] Cockpit Fresh and Sea Water Connectors Bob's Boat 1 969 06-20-2026, 07:16 AM
  2001 3500 tiera exspress Bucky 3 887 05-19-2026, 03:20 PM
  Water tank level sensors Final Pursuit 4 2,570 10-09-2025, 06:37 AM
