1995 3100 Open - Sliding Cabin Door
My sliding cabin door might be on its last leg.The door doesn't slide or glide very well and the rubber gasket around the plexy glass continues to fall out. What is the best way to fix this or is a total replacement my best bet? How complicated/difficult is the replacement? How expensive is the replacement? I would welcome any thoughts and/or advice.
Thanks,
Steve
(11-10-2012, 03:44 PM)Skinney01 Wrote: My sliding cabin door might be on its last leg.The door doesn't slide or glide very well and the rubber gasket around the plexy glass continues to fall out. What is the best way to fix this or is a total replacement my best bet?  How complicated/difficult is the replacement? How expensive is the replacement? I would welcome any thoughts and/or advice.
Thanks,
Steve
At the top and bottom of the door you will see 2 plastic buttons (1/2" wide) pry them off and use an allen wrench to adjust or tighten the rollers for the door. Fixed my same issue in 5 minutes.  Not sure what to suggest for the gasket, maybe silicone adhesive to replace the gasket might work.
Just did the adjustment on my 1995 3100 worked great. However on my boat I did not have rollers attached to the door. I have plastic slides that run inside of the tracks, no bearings to wear out. I add plenty of lube and now the door slides very nice
  [Tiara Sovran] 3900 stateroom door track replacement RtinthePNW 1 95 11-17-2026, 04:52 PM
Last Post: joshuawhite
  [Tiara Open] Cabin Laminate Repair- 3300 Open Boatworks 1 78 11-17-2026, 03:49 PM
  1995 3500 Express LFP/Inverter Install penneyma 0 686 09-09-2026, 07:09 PM
Last Post: penneyma
  Adding a generator to a 3500 open Simpleg1 1 2,002 09-09-2026, 06:53 PM
Last Post: penneyma
  [Tiara Open] Extend Swim Platform 1988 36 Open tomconroy 4 5,152 02-07-2026, 12:15 PM
Last Post: jgaudet2
