Hydraulic fluid reservoir cap for steering
So, I have a leak of Hydraulic fluid coming from the reservoir cap for steering.  My mechanic says that he cannot put new threads in the aluminum and that the only fix is to replace the entire helm portion of the steering system (for $750 for parts alone).  Have any of you had this problem and if so what did you do to repair it.  Who was the manufacturer of this system for the 1997 3100 open? I am hoping that there is some kind of repair part or kit without replacing the whole thing.  Any thoughts or ideas are greatly appreciated.
Dennis
I think pictures would help a lot.
Unfortunately I am to far from the boat at this time. The leak is coming from the little plastic cap right behind the steering wheel, between the wheel and the helm wall. They say it is a fill and breather cap.
If I remember correctly, I had a 1997 31 Open, the breather cap had an O-ring on it....... Not sure if yours has one or not but that may be the reason it appears to be leaking.... BTW my current Tiara which is a 38 Open has the same steering system and the breather cap also has an O-ring on it.... Both are Hynautics (Sea Star) steering systems...... M2C
(04-04-2016, 03:38 PM)ReelMagic Wrote: If I remember correctly, I had a 1997 31 Open, the breather cap had an O-ring on it....... Not sure if yours has one or not but that may be the reason it appears to be leaking.... BTW my current Tiara which is a 38 Open has the same steering system and the breather cap also has an O-ring on it.... Both are Hynautics (Sea Star) steering systems...... M2C
Yes, that is the cap I am talking about. Evidently it is threaded and supposedly the threads that the cap screws into is aluminum and they are stripped out. So it leaks even with the O-ring. I am going to try to contact the manufacturer to see if there is a fix besides replacing the whole unit.
Dennis
A little thread dope or compound or Teflon piping tape might seal the threads if there are any cuts too large? In combination with a a new o-ring it might not totally stop any leak, but minimize it a bunch. I'd try that before i spent any big dollars.  Simplest is usually easiest fix - learned from experience.
Let us know if it works.
Before I replace the entire unit I would re-thread the unit to the next size larger thread or install a "heli-coil" which would allow the original cap to be used. Would require cleaning the inside of the unit to ensure no metal chips get into the pump mechanism... Using the next size larger would also require a new screw cap that has matching threads....  Surprised that so much fluid is leaking..... Maybe Dakota773 fix may be the easiest/fastest.....
  [Tiara Open] Trim Tab Hydraulic System Bob's Boat 0 525 07-19-2026, 02:41 PM
Last Post: Bob's Boat
  4000 Express-Hatch & Table hydraulics; Anyone changed the hydraulic oil and filter? frank.koetter 5 4,857 05-06-2025, 09:57 AM
Last Post: Alan615
  Steering issues with engine down Capt. Tom 3 2,184 10-23-2023, 09:00 AM
  Dingy Ramp vs Hydraulic Swim Platform ds825x 9 8,550 08-01-2023, 03:04 PM
Last Post: ZQubed
  [Tiara Open] 3100 HT Hynautic steering ram p4pjc1 0 1,015 07-31-2023, 11:22 PM
Last Post: p4pjc1
