fuel sending unit
#11
(04-21-2016, 06:51 AM)Uhehner Wrote: To Photoman41
I suggest you install the new type water pumps on your 8.1's. The front crankshaft mounted units are failure prone,sometimes only lasting two years.
The new style side mounted pumps seem to be problem free. The mod kits are an easy fix. Capt.  George
Second that.
The previous owner had the crankshaft mounted units that weep (and weep a lot when they start to fail) that sprayed salt water all over that side of the engines all the way up to the decking above.  It took me a few days to figure out what the brown/rust colored line across the engine compartment ceiling was (boat was on the hard).  Immediately upon purchase I switched to the belt driven raw water pumps which work great (no weeping).
#12
(04-25-2016, 03:47 PM)Whefour Wrote: Hi, had a problem with our port side sending unit (2001 31 Open) and first replace with store bought, adjustable float. While it worked, I was not confident with the ablility for this unit to be accurate. We ended up buying a replacement from Amazon ( Moeller Marine Electrical Reed Switch Fuel Sending Unit ) for under 60.00 and installed in minutes...works perfectly.
Good Luck,
Eric
Eric,
Do you recall which Moeller unit you selected? According to their website, you need to know tank depth. Mine is 126 gallons but i do not know the physical dimension.
Hi,
The unit I ordered was Moeller Marine Electrical Reed Switch Fuel Sending Unit (18.5" Deep Tanks) , hope that helps.
Eric
#13
Not sure what year your boat is but my '99 3500 Open had the sending units go bad and I replaced them myself.  Here is a link to the units.  You will need to know the depth of the tank to make sure you get the right one and if you can't determine that I am sure Tiara will let you know.  My boat has the vdo gauges which were identical to the gauges on the 31 open I owned previous to the 35.
It is an easy fix, IIRC changing both took about an hour tops.
http://www.egauges.com/Tube-Type-Senders.../23212.htm
#14
(05-18-2016, 04:24 PM)1999R4 Wrote: Not sure what year your boat is but my '99 3500 Open had the sending units go bad and I replaced them myself.  Here is a link to the units.  You will need to know the depth of the tank to make sure you get the right one and if you can't determine that I am sure Tiara will let you know.  My boat has the vdo gauges which were identical to the gauges on the 31 open I owned previous to the 35.
Wish I would have waited until your reply. I bit the bullet and purchased through Tiara...$200
#15
Ouch, sorry I didn't see your post earlier. Well the important thing is that you have accurate gauges now.
  Looking for Help with Fuel Vent Issue - Tiara 2700 (1988) kahunamax 3 652 10-02-2026, 11:50 AM
  [Tiara Open] 93 3100 fuel tank sending unit. Joeboch348 1 722 02-18-2026, 09:15 PM
  Replacing fuel full hose 3100 Open Joeboch348 1 1,172 08-20-2025, 03:53 PM
Last Post: S4Survivor
Information 2000 express 4000 fuel system questions... bman440440 2 1,429 07-23-2025, 08:19 PM
Last Post: bman440440
  1993 Tiara Sport 220 Fuel in the Bildge (Leaking tank) bradcool 1 992 01-21-2025, 08:50 AM
