29 Open Engine Hatch Lift Switch
While routing some new wiring, I managed to pull off most of the wires to the rocker switch which controls the engine hatch. The wiring diagram in the manual is not user friendly showing only one wire. Can someone please help me with this. Either a more complete diagram or a picture of the wired switch would help a lot. Thank-you.
Bob
You probably have a 6 terminal DPDT switch ( double pole, double throw ) with the corner poles jumped together.  Use a meter to find the two power leads.  One will be plus 12 volts and the other negative 12 volts.  Probably red ( + ) and black (- ).  Connect the hot leads to the two center terminals.  Then connect the other two leads to the two terminals on one end of the switch.  If you press up and it goes down, reverse the two center leads.
 Let us know how you made out.
Capt.  George
Thanks Capt. George. That's exactly the switch I have. I'll give it a go tomorrow afternoon. Thanks again.
Bob
Thanks to Capt. George the hatch is now fully functional.
Bob
Drunk
(05-22-2016, 10:37 AM)Bob Hibbs Wrote: While routing some new wiring, I managed to pull off most of the wires to the rocker switch which controls the engine hatch. The wiring diagram in the manual is not user friendly showing only one wire. Can someone please help me with this. Either a more complete diagram or a picture of the wired switch would help a lot. Thank-you.
Bob
Hay,hay, your hatch switch , is just a polarity revurseing switch the 2 center connectors are one is hot the Luther is ground, it doesn't mater,
Know you 4 more connectors, top left will be one feed from the auctour, and bottom right the number 2 feed from the actuwator, thier should be a short jumper wire that connects the last  2, connectors  if the switch  is backwords revurseing the the  2 acturwtor wires or call  larry at 913-927-8026
  [Tiara Open] Main DC Breaker for 1995 Tiara 36 Open petrienorris@gmail.com 2 1,681 07-15-2026, 08:06 AM
  1988 3300 Open - Voltage drop when lowering engine hatch or honking horn Pluto 3 1,581 03-24-2026, 09:46 AM
  2001 3100 open generator runs but doesn't generate electricity lakesidevu 5 3,045 11-14-2025, 01:01 PM
  DC Panel Volt/Amp Seclector Switch Replacement Peave 4 1,795 11-07-2025, 02:50 PM
  [Tiara Open] 2005 TIARA 2900 OPEN DC ELECTRICAL SCHEMATIC COPY HIGH SPIRTED 2 3,020 07-05-2025, 12:54 PM
Last Post: HIGH SPIRTED
