Fuel Pressure Regulator O-Ring on Crusader 8.1 MPI
I had both fuel control cells replaced this year (2005 Coronet).  There is a service bulletin on them due to modern fuels eroding a protective seal.  Shortly after the control cells were replaced, I started to get fuel leaking from the fuel pressure regulator on the starboard engine.  My mechanic removed the seal and found a small piece of debris on the O-ring.  He thinks a small piece of nylock got into the seal from the fuel control cell replacement. He has ordered replacement O-rings and I am awaiting installation of those.
Has anyone experienced a leak from the fuel pressure regulator on this engine?  If so can you provide any insight?
Dave
  Upgrading to fuel injection Joeboch348 1 1,361 11-26-2025, 12:14 PM
  [Tiara Open] Raw fuel smell while running WOLFDAWG71 3 1,645 11-19-2025, 07:43 PM
Last Post: Joeboch348
  Fuel Filler Hose Joeboch348 1 1,086 08-18-2025, 04:24 AM
Last Post: Capt. Paul
  [Tiara Open] 2003, 3100 with Twin Crusader 8.1L MPI Gas Engines jmdegraff 2 1,586 06-16-2025, 08:07 AM
  [Tiara Open] 454 XLi Low voltage at electric fuel pump Mtgates44 3 2,219 04-27-2025, 10:19 AM
Last Post: Mtgates44
