Fuel tank selector valve air leak.
I have a 1998 Express, with 3208 CATs. Has anyone seen an air leak in the fuel tank selector valve. I did a filter change and am now drawing air into the filter from upstream, but only when set to draw from the port tank, belly tank ok. All hoses and connections are tight. Had no problems prior to the filter change, but the selector was very hard to turn when shutting off fuel just prior to the filter change. That is why I suspect the valve. Also the valve stem has about 3/16" play in and out, which seems unusual. They appear to be Groco 6 port valves. Valve is hard to get to. Can they be rebuilt or just replaced?
Any help appreciated.
  Blown Valve Seat on a my starboard 2005 Cummins 6CTA8.3L-480CE with only 1061 hours Another Tradition 1 1,116 07-29-2026, 02:41 PM
  2000 3500 Express 6BT 5.9 Best Fuel Economy RPM's JMGCINCY2023 1 1,980 10-09-2024, 02:30 PM
  [Tiara Sovran] Anyone cleaned fuel vent flush mount Donaldjames 0 1,289 05-09-2023, 11:55 AM
Last Post: Donaldjames
  [Tiara Open] water in fuel alarm lesliepawlak@yahoo.com 2 2,435 08-11-2022, 06:25 PM
Last Post: lesliepawlak@yahoo.com
  Tiara Coronet water tank fill problem d5dekeyser 1 1,818 06-07-2022, 08:26 PM
