Need Salon dinette table and stems 1989 31'
We just recently purchased a 31' 1989 tiara and the previous owner removed and discarded the dinette table and stems (which also converts the dinette to sleeping)for his comfort. We are looking to buy a replacement.
Welcome aboard!
That is very sad that the table was discarded.
I believe that Garelick supplied the original table hardware. You can look them up on the internet and see all the harware they offer. The original set up had two sets of base pipes (long for dinning and short for converting into berth). You are likley going to have to buy two long sets and cut one down (do not do this until you have the table top made so you know the thickness) to the right height.
The table top was custom built by Tiara. They no longer build that table, so you are most likely going to have it custom made. The original table was marine plywood with teak veneer on top and solid teak edge trim. The table shape has to be exact if you are going to use it in the berth configuration. It must be shaped to fit the curvature of dinette. The best way I found to have a table built was to cut the shape you want from cardboard and take it to a local wood furniture builder. I would buy the table hardware and install the cardboard on the hardware to make sure it will work properly. Then you can use the cardboard template to have a cushion made (for converting to a berth) if you do not have that either.
The best case would be to find another Tiara 31 of the same vintage you can borrow the table from to have a new one made.
It is unlikely you will find a pre-owned Table as those that don't use the tables, keep them for resale.
Good luck and let us know how it works out.
You could try calling Tiara and see if they have the old table templates, but I doubt it. Your model 31 ended production in 1992. It is highly unlikely they would keep the templates for 21 years. You never know thought, it may be worth a call.
  1989 L-shaped seat pshrubb 0 1,175 05-30-2022, 07:26 PM
Last Post: pshrubb
  For Sale: Pedestal Table Legs and Extensions CptRob 2 2,485 06-09-2021, 07:46 AM
Last Post: Non$ense
  [Tiara Open] Looking to buy 1989 Tiara 36 "L" shaped passenger seat module pshrubb 2 3,927 03-02-2021, 11:58 PM
Last Post: thmaine1
  Tiara Cockpit Table / sunbed + Cushion : South Florida : $250 Tiara2900FL 0 1,832 09-17-2020, 12:46 PM
Last Post: Tiara2900FL
  Wanted Taco Table leg Iceman20 0 1,487 06-12-2020, 12:05 PM
Last Post: Iceman20
