38 open
Purchased 38 open in July. 2003 which we love .winterizing for first time so I have many questions.how do you get to fresh water tank to drain.boat came with no zincs on tabs. I noticed corrosion on tabs and want to put zincs on which ones should I get.thx bill ps using my wife's address because I can not get online with my old email address
(11-06-2016, 07:01 PM)Susanwalter Wrote: Purchased 38 open in July. 2003 which we love .winterizing for first time so I have many questions.how do you get to fresh water tank to drain.boat came with no zincs on tabs. I noticed corrosion on tabs and want to put zincs on which ones should I get.thx bill ps using my wife's address because I can not get online with my old email address
I drain the water tank as best I can using the fresh water pressure pumps through the galley faucets..... Once the majority of water is out the tank the pumps won't shut off as they can't build up pressure that shuts the pumps off.. Once this occurs I shut the pumps off at the circuit breaker panel.... I then drain the hot water tank using the drain valve on the tank itself (ensure the hot water heater circuit breaker is off before draining the hot water heater). There should be 2 valves on the hot water tank that allows you to isolate the hot water tank from the rest of the system .... Instead of using non-tox antifreeze (the pink stuff) I hook up an air compressor to the dockside water inlet and set the compressor to 40 PSI.... I first blow out the remaining water in the hot water tank and then shut the 2 valves mentioned earlier... This isolates the hot water tank from the rest of the system. I then open each faucet one at a time and let the air blow out the remainder off water in the system.... Seems to work for me as I've been doing this for 10 years on the 38 and did the same for 10 years on my previous 31 Open....As a point of fact I'm also located in the northeast where the winters are very cold and haven't had a problem yet....Also no smell/taste in the spring from the non-tox when I pressurize the system with fresh water ...M2C
WRT to zinc's on the trim tabs... I use ones that attach to the tabs using the screws that attach the tab itself to the hydraulic piston (BSMBTANODE).... There available from Bossler & Sweezey.... (http://www.bandszincs.com/zincs/item/67/Trim-Tab)
Thanks for info.i had a33 open before and would blow out system also.owners manual said to drain tank first but it seems impossible to get to tank.i did the pink stuff because I was concerned with the residual that pump didn't get.i agree the taste takes awhile to get rid of.i have Cummings 480 Che's in my boat.do you have Cummings and if so do you have preheat.bill wading River ny.
I also noted your post on leaking hatches.my are leaking from the seal between the acrylic and frame.I would like to change the acrylic when I rebed.where did you get acrylic for hatch.bill
Also do you do anything special to engine s. I ran anti freeze through and then drained muffler.seemed most of anti freeze came out shaft so I emptied muffler. Is this typical.
(11-07-2016, 10:04 AM)Susanwalter Wrote: Thanks for info.i had a33 open before and would blow out system also.owners manual said to drain tank first but it seems impossible to get to tank.i did the pink stuff because I was concerned with the residual that pump didn't get.i agree the taste takes awhile to get rid of.i have Cummings 480 Che's in my boat.do you have Cummings and if so do you have preheat.bill wading River ny.
I don't believe you have to empty the tank completely although if that makes you happy that's it.... The tank is Aluminum and with the little that may be left I look at it as a big ice cube tray.... Never had a problem although there is always a first time.....Agree it's impossible to drain completely....  My 2003 has 450 Diamond Series 6CTA Cummin's.... Great engines......Can't remember the last time I preheated the engines. They start easily, even after sitting the entire winter....
Not sure which post you read regarding leaking hatches but it's not mine.... My hatches are solid and don't leak at all.....
I stay in the water year round and get a short haul every 2 years to do the bottom and change zinc's (replace shaft zinc's during the summer of the 2nd season using tanks and going under the boat)... I change  engine oil/filters, fuel filters (Racor's/engine), and fresh water cooling filters that are on the engines every year before I lay it up for the winter. I also drain the mufflers and saltwater intake strainers after the engines are winterized w/non-tox antifreeze....
Looks like you live near me.. We boat out of the North Shore in Smithtown. Where do you keep/boat from?????
Yes we live in wading River and keep boat in Stirling harbor in greenport.im still getting use to this site so therefore my mistake on the hatch post. It was another person.i have many winter projects set up on boat so if you don't mind I will be pestering you because the boats are identical.
No problem and welcome as a Tiara owner. Know Greenport extremely well as we have stayed there many, many times.... Use to go to Townsend Manor but most recently (last 6-8 yrs) at Mitchell's Marina right in Greenport.....If I can be of more help, feel free to contract me...
  3500 Open deck lift piston drmiagi11 6 1,235 11-20-2026, 10:03 AM
  38 - 43' Tiara Open Comparision ClayPlatt 8 8,885 10-27-2026, 02:44 PM
Last Post: tk17
Last Post: North Star
  1989 33' Tiara Open - Bedding Question jgaudet2 2 2,331 12-21-2025, 10:02 AM
Last Post: jgaudet2
  2003 3100 Open cabin privacy curtain. Hilary 3 3,013 12-02-2025, 02:13 PM
Last Post: E-MAN
