Inverter install
I have just purchased a 05 Coronet with "dockside" air. Anyone installed an inverter in a Coronet?
Hi Henry!
A traditional inverter won't handle the startup load of the air-conditioning unit and even if it did, the amount of batteries needed to operate it for any length of time would be impractical.
I have seen before AC alternators that could handle the load of the air-conditioning depending on engine RPM. I believe at idle, they won't be able to handle the startup load, off idle and they should be fine. The AC alternators that can handle this load won't be cheap, but they are less expensive and require less maintenance than a traditional generator.
Good Luck!
  Replacing Inverter on 1998 Tiarra 3100 Pknappe 1 741 03-24-2026, 09:36 AM
  Inverter- How to use and location 39 Sovran August Rush 3 2,020 09-02-2025, 09:49 AM
  [Tiara Open] 1994 Tiara 31' Open Charging and Inverter problems: mholts13@yahoo.com 3 4,554 11-18-2024, 10:51 PM
Last Post: Polesetter
  4000 Express inverter location dan@superstamper.com 2 2,244 08-09-2022, 06:09 PM
Last Post: Jfhaas
  New Charger/Inverter Set-up -- Need Help MC1600 4 3,804 02-16-2022, 03:43 PM
Last Post: MC1600
