Tiara Open 3100 Dash lights
Just bought a 1989 3100 open. There are four lights on the port and starboard side of the dash. Any hint on what these lights are/ Thanks
Alarm lights. Sounds like the labeling has worn off. Should be tied to a buzzer as well. Can kind of see in attached pic from my old 1988 31'.
Think was:
High Temp Engine
High Temp Trans
Low Volts
Low Fuel
(06-05-2017, 05:05 PM)Lured Away Wrote: Alarm lights. Sounds like the labeling has worn off. Should be tied to a buzzer as well. Can kind of see in attached pic from my old 1988 31'.
Think was:
High Temp Engine
High Temp Trans
Low Volts
Low Fuel
Thanks. The bottom light keeps flickering. All Gauges show good temps and the gas was half full
how much fuel do you have in your tanks wen the low fuel light starts flashing?
  Replacing Inverter on 1998 Tiarra 3100 Pknappe 1 680 03-24-2026, 09:36 AM
  2001 3100 open generator runs but doesn't generate electricity lakesidevu 5 2,949 11-14-2025, 01:01 PM
  Tiara 3600 Courtesy Lights No Longer Available Roweje 0 1,118 11-10-2024, 09:17 PM
  LED Lighting Upgrade 3100 Open TWO SUNS 2 6,837 07-11-2024, 02:07 AM
Last Post: Pop Alexandra
  [Tiara Open] Switch for Lights in steps on 2007 3600 Ope Roweje 0 1,029 06-15-2024, 07:50 PM
