Back of horn dripping black scum
Hi all. My 2000 3100's horn consistently leaks black crud down the boat's sides. When I took the hron cover off, I see there is a rubber backing, which I think is deteriorating, and therefore causing dark-colored water streaks, whenever it gets wet.
Has anyone found a solution for this?
Thanks!
I had the same problem with my rod holder liners. Took them out and through them away. you might try making a new gasket or dipping it in a sealer such as varnish. Hope this helps.
Capt. George
Mine is doing the same thing. I am going to research and If I find anything I will post here.
  Horn stanfarbman 1 1,184 07-08-2025, 10:31 AM
Last Post: peakay
  C39 Horn Replacement - location of the Compressor? fishtiara17 3 1,410 02-26-2025, 10:14 PM
Last Post: Napercpl
  [Tiara Sovran] Air horn compressor Four Winds V 2 2,094 01-04-2024, 11:55 PM
Last Post: Four Winds V
  [Tiara Open] Trumpet horn replacement Capt. Tom 1 1,637 09-15-2023, 07:54 PM
Last Post: lakesidevu
  Round Black Door Latches Matta0413 3 2,549 07-18-2023, 07:58 AM
