Hard bottom inflatable tender
Threads: 2
0
Home Port: Naples FL
Vessel Info: 2015 Tiara Coupe
IPS 600
I have a 2015 Tiara 44 Coupe and would like to put a hard bottom inflatable on my hydraulic swim
platform and need your advise. Most of these are in the 500 -600lb range. My concern is that by doing this it will require me to change the factory props and potentially reduce our top cruising speed.
What have other owners done?
Threads: 3
20
Home Port: Lake Michigan
I doubt the addition of a RIB will force you into new props. tiara does a good job of specing props so that the engines are able to achieve manufacturers rated WOT rpm (plus a couple percent) at max weight. 600 pounds is about the equivalent of carrying an extra 80 gallons of fuel which isn't much for a boat that size. If you tend to run with a lot of gear/fuel/passengers on board you may need to tune the props a little.
Threads: 7
0
Home Port: Saugatuck, MI
Vessel Info: 2007 Sovran 3900, IPS Volvo
(11-17-2017, 06:06 PM)Water Gate Wrote: I have a 2015 Tiara 44 Coupe and would like to put a hard bottom inflatable on my hydraulic swim
I put a Freedom Lift and a 450 lb hard bottomed Capelli on a 3900 Sovran, and the boat still performs great. Only a little noticeable bow rise coming up to plane, so put 100 lb ballast under forward bed and that was easily corrected. IMO, I actually prefer the way the boat handles w/RIB loaded than without. No prop changes.
http://i67.tinypic.com/2h5i1z7.jpg
Threads: 2
0
IPS 600
What brand and size did you get. How well does it plane with 2 people. Thanks
Threads: 7
0
(11-19-2017, 04:45 PM)Water Gate Wrote: What brand and size did you get. How well does it plane with 2 people. Thanks
We bought a Capelli 340
http://capelli-usa.com/portfolio-view/capelli-340/
We bought our Tiara last Fall, then went to FTL boat show to research lifts and RIB's. We looked at about everything on the market. The Freedom Lift folks were at the show and helped us determine weight and size that was right for our boat...a few brands fit the bill...for us it ended up being between Walker Bay and Capelli, and we liked the uniqueness and reputation of the Capelli. We liked also liked it because it was narrow for access to swim platform (with the Freedom Lift, we have about 40" of walking space between dinghy and transom), just the right length for our boat, and 441 lb with motor (we bought a 20 horse to save even a little more weight). We boat on Lake Michigan...in 1-2's she planes out well...perhaps another 4-5 seconds than usual, and it is usually just two of us. We were in 5-6's across the lake this summer with the two of us, and she was stable and firm. I'd think with your added length and the quality of a Tiara hull you'd be just fine with something similar, and see minimal impact to performance. PS. The Freedom Lift folks helped us test the ballast up front to guage impact...it's always an inexpensive option to help adjust performance if you need it, especially if usually just the two of you. Good luck!
Threads: 2
4
I installed a freedom lift on our 42 open last season. Although the unit is rated for 800+lbs, I tried a zodiac that was just shy of that and felt it was too heavy for the boat. I believe we are going to go with the new Walker Bay generation light that is just under 600LB wet. I see you're in Naples, a friend (Nathan) runs Inflatable Boats of Florida located there and I believe he still has one in stock. May be worth a look.
https://walkerbay.com/rigid-inflatable-b...ation-lte/
https://inflatableboatsofflorida.com/
Max
Threads: 8
0
Home Port: Mystic, CT
Vessel Info: 2008 Sovran 4300 IPS600
I would think that with a hydraulic swim platform, there would be no need for a Freedom Lift, just a set of cradles. I have the FL on my 43 Sovran and feel that because it is mounted so far aft, performance is affected, however, it is hard to tell since i bought the boat with the lift....which happens to be terrific. I have a 11'2" Achilles HB with a 20 HP motor and I believe it weighs in at around 240 lbs..
Good Luck
Threads: 7
0
(11-21-2017, 02:54 PM)mobil1 Wrote: I would think that with a hydraulic swim platform, there would be no need for a Freedom Lift, just a set of cradles. I have the FL on my 43 Sovran and feel that because it is mounted so far aft, performance is affected, however, it is hard to tell since i bought the boat with the lift....which happens to be terrific. I have a 11'2" Achilles HB with a 20 HP motor and I believe it weighs in at around 240 lbs..
Good Luck
you are correct. I was replying based on the load limits and recommendations for different size boats. The FL folks are good about advising on weight vs. performance...didn't mean to confuse.
Threads: 1
0
Home Port: Newport Beach,CA
Vessel Info: I work for the Westcoast Tiara dealer Silver Seas Yachts. I'm one on the lucky few who gets to try all the models and engine combos.
