Threads: 1
0
Home Port: Pnw
Hello, just sold my ‘88 Ocean Alexander 42. Looking at a 2004 42 Open with QSM 11s. Cruise half the time and fish the other half.
How slow do the QSMs go at idle? Are trolling valves an add-on option with these engines?
Threads: 14
11
Home Port: Kings Park, NY
01-14-2018, 01:40 PM
(This post was last modified: 01-14-2018, 02:50 PM by ReelMagic.)
Not sure about the 42 with QSM 11's but I own a 2003 38 Open w/Cummins 6CTA's... Trolling valves were an option on my boat and I wish the original owner purchased them as trolling with both in gear at idle is to fast under most circumstances. Usually troll with one in gear and the other in neutral (running). Boat tracks well even with one engine and auto pilot seems to hold course as well... M2C
Threads: 5
0
Home Port: NORTHPOINT Marina, Winthrop Harbor IL
Vessel Info: 2006 Cummins QSC’s
You can always add trolling valves.
Threads: 94
1
Home Port: ludington michigan
Vessel Info: 2003 4200 open qsm 11 660hp
11-03-2018, 01:55 PM
(This post was last modified: 11-03-2018, 01:55 PM by honest mark.)
if you do run 1 engine how slow do you think you can get the boat down to??? 2mph???? are trolling bags an option????
are adding trolling valves a big job???? approx cost????
Threads: 94
1
when using trolling valves do you keep the boat in neutral and then use the trolling valves or do you put the engine in gear ??
