Replacement Radar Arch Dome Light?
I'd like to replace/upgrade the Perko dome light in the radar arch of my 2002 3100 Open. Has anyone replaced theirs and have a good LED light to recommend?
The wife would like one that has soft white and blue lighting....I just want something that's bright enough that I can actually see things while at the helm.
Thanks!
http://www.i2systems.com/marine-led/apeiron-tri-light/
These are ones that i used to replace on my 3500 arch. Mine are powder coated white. I got mine about 4-5 yrs ago so they may have changed a little byt they work great. Red/White/Blue all 3 colors in one light. I also put them in my cockpit as well.
(02-05-2018, 06:18 PM)trit21 Wrote: http://www.i2systems.com/marine-led/apeiron-tri-light/
Fantastic. Thank you. Was it a direct fit or did you have to increase the cutout diameter or drill new holes for the screws? Looks like a great light!
From what I remember I had to open the hole a little with a dremel but don't remember how much. Probably had to drill new mounting holes as well but it was a while ago and I don't exactly remember. Wasn't a big deal otherwise I would have remembered that.
(02-07-2018, 05:33 PM)trit21 Wrote: From what I remember I had to open the hole a little with a dremel but don't remember how much. Probably had to drill new mounting holes as well but it was a while ago and I don't exactly remember. Wasn't a big deal otherwise I would have remembered that.
Thanks!
Lumitec mirage, great lights and some models are Simma Le with standard switch
You could also consider the 24v puck lights from NDR, in case you're looking for some high quality alternatives.
Or you could just replace the bulb with a LED bulb. I've done most of mine in the boat and they work great.
Marinebeam.com
  DC Panel Volt/Amp Seclector Switch Replacement Peave 4 1,725 11-07-2025, 02:50 PM
  [Tiara Open] Cabin light bulb replacement Bbarroll 2 3,118 06-06-2025, 03:57 PM
Last Post: Joe.dammann
  [Tiara Open] Push button breaker 12v replacement Mydiamond 2 1,761 09-28-2024, 09:01 AM
  Nav/anchor Light Switch Joeboch348 5 3,340 06-29-2024, 09:55 AM
Last Post: roboh20
  1994 43 Open Cockpit Courtesy Light Fixtures carbon20 1 2,170 11-12-2023, 11:37 AM
Last Post: Afarneti
Users browsing this thread: 6 Guest(s)
