Old Raymarine 215 VHF Replacement
Going into 2nd season with my 2002 3100 Open. She still has the original vhf radio installed and the mic cord is all worn out. Time to replace it but really do not want to have to make the hole any larger as I am planning on all new electronics in the next year or so and want to keep as much room available as possible. Has anyone found a replacement with the exact same dimensions as the Ray215?
(05-30-2018, 07:42 AM)Matta0413 Wrote: Going into 2nd season with my 2002 3100 Open. She still has the original vhf radio installed and the mic cord is all worn out. Time to replace it but really do not want to have to make the hole any larger as I am planning on all new electronics in the next year or so and want to keep as much room available as possible. Has anyone found a replacement with the exact same dimensions as the Ray215?
I put this one in my Tiara 2 weeks ago..... I highly recommend you go with a DSC unit and get AIS on the boat
http://www.icomamerica.com/en/products/m...fault.aspx
Capt. Brett M. Sause
USGC Master Licensed Captain
443-220-4339
USCG Master Licensed CaptainĀ
443.220.4339
www.themarineminute.com
Thanks Brett. Looks like a great unit but it has a larger footprint. I was hoping to find soemthing that has the same dimensions.
Got to side with Capt Brett on this one. The Icom M506 is an Awsome piece of equipment. otherwise I think standard horizon has a smaller unit that may fit with a cover plate. you can also get a command mic setup from Icom (m400 black box) and hide the base unit behind the dash. Then it's just a cover plate until you redo your dash.
  Waste Holding tank replacement danllovi 9 12,411 03-18-2024, 09:46 AM
Last Post: Aashvi78
  Jabsco Electric Head Replacement Newbie7749 6 4,335 07-04-2023, 05:14 PM
Last Post: ReelEnjoyment
  [Tiara Open] OEM Fiberglass or replacement hood on console Abear68 1 1,886 02-25-2023, 08:38 AM
  [Tiara Open] Portal or thumb screw fastener replacement part SaKiawa 0 1,406 08-17-2021, 05:45 PM
Last Post: SaKiawa
  Replacement Scuppers Matta0413 17 22,894 03-31-2018, 08:55 AM
Last Post: jholtco
