58 Sovran
The 58s are coming on to the used market at a price, if I stretch far enough, I may be able to consider; moving up from our 42 Open. Just wondering what the experience has been with these boats, their 3 engine configuration and the then new forward facing props. Any high points, low points, I should consider in looking at these used Tiaras?
Jim, judging from the number of replies it looks like the rich guys are on a different blog. Hope you took the leap! Beautiful boat.
This is an old post, but I'm going to respond as others may find it useful.
I have sold two 58 Tiaras in my career. I sold Hull #1 at the Miami Boat Show when it was first released and I sold Hull #14 or #15 a few years later.
The 58 is a great boat in my opinion. It has a nice interior layout, although small for a 58' boat. It compares more in size with the old 52 Sovran in terms of interior space, although the 58 is laid out in a much better way. The 58 is fast, nimble and fuel efficient. It is truly fun to drive Captain .
The Triple IPS set up is nice. Yes, you have three engines and drives, but those three engines are much smaller and far less costly to maintain than two larger Diesels . The drives are another matter however. The drives are expensive to maintain and do require a fair amount of service (Oil changes, anode replacement and periodic adjustments) . In the end it is a wash between the savings on engine maintainence and the more expensive drive service. The triple IPS set up had some issues when the 58 was introduced. There were some drive overheating issues (the twin engine installations on the smaller IPS boats did not seem to suffer this issue Clap ). Many of these boats have had drive coolers installed since they were first released. If you are looking at a pre-owned 58, make sure you get the service records and that the drive cooling issues are resolved. Pay special attention to the sea-strainers and corrosion around the sea-strainers. The original sea-strainers were notorious for leaking. The sea strainers are located above the alternators, so the water would hit the belt and get spun around the engine room. As long as the sea-strainers have been updated and the corrosion issues addressed, this should be a none issue.
IPS with joystick control is a marvel. Unless you are a master inboard operator , able to dock the largest vessel in high winds and current with ease, you will appreciate the IPS system. As far as the front facing inboard propellers, I have had no issues with them. If you run aground, it matters little where the props are mounted.
The 58s are light. They were built light for better fuel economy and better performance. They are not heavy sea boats. If a majority of your boating is slogging it out in 5' to 8' seas on long trips, the 58 is likely not your boat. If however you are a fair weather boater (most of us are - come on and admit it! Wink ) and only hit the rough stuff occasionally, the 58 is a pleasure to operate and you will appreciate the low fuel burn and high speeds.
  [Tiara Sovran] 3900 Sovran helm comfort in summer wejonesIII 6 4,124 07-24-2025, 12:08 PM
Last Post: coltsneckbob1
  [Tiara Sovran] Needed 2006 4300 Sovran Owner's Manual floridajack 2 3,497 01-19-2025, 06:33 PM
Last Post: rjbevco@gmail.com
  [Tiara Sovran] Removing Salon Door in 2004 Tiara 44 Sovran Feetwet 4 4,001 06-08-2024, 10:10 AM
Last Post: Feetwet
  Sovran 4300 Performance with IPS600 turbobug56 1 2,554 05-25-2024, 02:11 PM
Last Post: turbobug56
  3900 Sovran Owners Question - Seating in Salon Area minnehahas 2 2,302 05-25-2023, 10:36 AM
Last Post: Donaldjames
