Head Door Locked from the Inside
Somehow the head door of our 2002 3100 Open has been locked from the inside. Has anyone run into this and have any ideas for how to unlock the door? I've removed the hardware from the cabin-side door handle and there does not appear to be an way to access the locking mechanism. Any help would be appreciated!
I have the exact same boat and have had that problem. It was pretty easy to get open with a very small flay head screw driver. You just push the door latch over with the screw driver. Like the old credit card trick
(09-06-2018, 11:47 AM)Matta0413 Wrote: I have the exact same boat and have had that problem.  It was pretty easy to get open with a very small flay head screw driver.  You just push the door latch over with the screw driver.  Like the old credit card trick
Thank you! I was able to work the lock over with a screw driver while turning the handle as much as it would go while locked. Door opened and problem solved. Thanks!
  bathroom door handle fuzzy 2 743 07-18-2026, 05:43 PM
Last Post: fuzzy
  [Tiara Open] Access cover to sliding door on 43 open MariTime2 0 1,068 12-14-2025, 05:34 PM
Last Post: MariTime2
  Transom Door/Gate Repair MC1600 4 4,693 08-25-2025, 10:53 PM
Last Post: Splendor
  [Tiara Open] Water under Quartz flooring in head benmaser 0 794 06-16-2025, 02:24 PM
Last Post: benmaser
  1990 3100 open - can I add a transom door? 604.jim.smith@gmail.com 0 702 05-27-2025, 04:49 PM
