Tiara Open Cabin door
I’ve had my 91’ 33 Open since 2012 and love it. I boat on the upper Chesapeake, maintaining it with an “open checkbook” sometimes to my wife’s dismay.
The cabin door now takes two hands to close as it is not gliding properly on the bottom track. Can someone with any hands on experience give me some pointers as I’d like to do this over the winter.
How difficult is it to remove? As
to rollers and track, Tiara no longer carries.
Thank you
Paul ....aka pztuna
(11-17-2018, 05:25 PM)pztuna Wrote: Vacuum the track, spray it with WD-40, that's what i do with mine, it works great.   Use a corse rage with a screw driver to clean out the tack really well, and repeat.
Thank you
Paul ....aka pztuna
Capt. Brett M. Sause
USCG Master Licensed Captain
443.220.4339
www.themarineminute.com
I owned a 1997 31 Open for 10 years and had to adjust the door trucks/rollers located at the bottom of the door several times to make it roll easier... I agree cleaning the track helps but over time I found the lower roller trucks moved somewhat making the door hard to slide/roll... Not sure if you are aware but at the bottom of the door there are 2 plastic plugs, 1/4", that will expose Alan screws used to adjust the lower door trucks. I made this adjustment and the door moved easily... M2C...
Thank you very much for both suggestions. I’ve tried to clean the track in the past, admittedly not as diligent as suggested.
If the cleaning still leaves it tight, I’ll try the adjustment route. I was not aware of the location of the screws beneath the plastic caps.
Thank you both and I’ll let all know how successful I am.
  bathroom door handle fuzzy 2 722 07-18-2026, 05:43 PM
Last Post: fuzzy
  cabin lights honest mark 2 2,010 04-05-2026, 10:25 AM
  [Tiara Open] Access cover to sliding door on 43 open MariTime2 0 1,063 12-14-2025, 05:34 PM
Last Post: MariTime2
  Transom Door/Gate Repair MC1600 4 4,673 08-25-2025, 10:53 PM
Last Post: Splendor
  1990 3100 open - can I add a transom door? 604.jim.smith@gmail.com 0 695 05-27-2025, 04:49 PM
