Threads: 25
0
Home Port: Punta Gorda, Florida
Vessel Info: Looking to purchase a 3100 Open
Live in SW Florida
How do I get it to stop?
Tiara 3100
Threads: 14
11
Home Port: Kings Park, NY
I suspect your window washer system is the same as I had on my 1997 31 and currently on my 2003 38 Open.. The washer system utilizes the fresh water pressure system as a source of water and there is a solenoid that allows pressure water to flow to the washer system when the switch is depressed on the dash. The solenoid for both boats is mounted in the ER on the forward ER bulkhead on the starboard side... I'm assuming the switch is OK and the solenoid is stuck partially open... A guess... M2C
Threads: 12
0
Home Port: South haven,mi
Vessel Info: 2006 3200 0pen 8.1 crusaders
If they don't see regular use they will stick open when used. Either use often or don't use at all.
