2003 42 open
with the cummins qsm 11 660 hp does the boat come with a low idle switch, for docking and going thru the harbor ??? if so what will that take your speed down to ??? approx??
I can't speak for the cummins, however our C12 powered boat has a high and low idle. High idle is 700RPM and the boat makes about 7.5kts (and a sizeable wake). At low idle, we're at 550rpm making about 6.2kts and still somewhat of a wake. Entering and leaving marinas, we're in and out of gear constantly otherwise I get (understandably) yelled at. You can make about 5kts on 1 engine and the boat will track straight with about 24 degrees of rudder.
That being said, the torque along with the boat being extremely well balanced makes it great to handle around the docks...
Max
38’ Open w cummins has the low idle switch and it’s very helpful...
thank you for all the help
I completely agree with Maxwell. I have a low idle switch on my 4200 open, but still too fast for the harbor. I run one engine and switch off!
(03-16-2019, 12:11 PM)miller2016 Wrote: I completely agree with Maxwell. I have a low idle switch on my 4200 open, but still too fast for the harbor. I run one engine and switch off!
Careful with transmission. Engine off no trans fluid pumping through transmission may cause problems.
  3500 Open deck lift piston drmiagi11 6 1,308 11-20-2026, 10:03 AM
  38 - 43' Tiara Open Comparision ClayPlatt 8 8,932 10-27-2026, 02:44 PM
Last Post: tk17
  Delaminated hull 2003 4000 express Steve Bosse 6 1,625 10-12-2026, 03:46 PM
  2001 3500 open, diesel exhaust flanges? North Star 4 1,690 02-24-2026, 08:55 AM
Last Post: North Star
  1989 33' Tiara Open - Bedding Question jgaudet2 2 2,355 12-21-2025, 10:02 AM
Last Post: jgaudet2
