Windshield Wiper removal 2001 4100
Can someone give me guidance on how to remove wiper arms on a 2001 4100 Open. There is some dissimilar metal corrosion happening preventing the cowling over the motor axle to pivot up. It
Usually the arms flip up and stay up under spring tension. Then there is a tab under the arm that must be lifted away from the motor end of the shaft while pulling the arm assembly off the splined shaft. Some twisting and rocking will help. A little penetrating oil might also help if you cover the windshield with a plastic bag. In the worst case, drill a hole in the cap and spray some penetrating oil in there. It looks daunting but I have always gotten them off. Capt. George
Thank you, I'll have another look at it.
  [Tiara Open] Cockpit bolster removal Rick B 0 93 11-14-2026, 12:15 PM
  Windshield Leak tip TIARACRREP 35 42,427 09-23-2026, 11:53 AM
  [Tiara Sovran] Wiper Blades 3900 Sovran Euphoria38 1 571 08-31-2026, 10:34 AM
Last Post: Herrema4
