DRYBOAT
HAVE A WET HULL, I DID BUT NOT ANYMORE!!
MY JOURNEY STARTED WITH A SALES CONTRACT AND UPON THE BUYER'S SURVEYOR REPORTING HIGH LEVELS OF MOISTURE IN THE HULL, THE BUYER WALKED.
SO I COMMISSIONED A SURVEYOR TO DO A COMPLETE MOISTURE SURVEY OF MY 38' PURSUIT OPEN EXPRESS AND FOUND THAT THE STARBOARD HULL WAS NEAR COMPLETELY WET BOW TO STERN AND A SMALL PORTION OF THE RIGHT REAR STERN. I WAS REFERRED TO A PARTY THAT HAD A SYSTEM THAT SUCKED THE MOISTURE OUT OF THE HULL WHICH TOOK SEVERAL MONTHS. AND I HAD TO TAKE THE BOAT TO HIM. FORTUNATELY HE WAS BACKLOGGED FOR 16 MONTHS.
YOU MAY WONDER WHY I FELT FORTUNATE, WELL I FOUND "DRYBOAT" AND TALKED THINGS OVER WITH THE OWNER, SCOTT RICHMOND. HIS METHOD AND SYSTEM EVAPORATES THE MOISTURE WITH HEAT AFTER A COUPLE MONTHS. AND DRYBOAT BRINGS THE EQUIPMENT TO MY LOCATION!! SO 2 WKS LATER SCOTT'S ASSOCIATE, JOHN BARTNICK, ARRIVES WITH THE TRAILERED EQUIP, SETS IT UP AND ITS RUNNING IN 1 DAY, CHECKS THE SYSTEM PERIODICALLY OVER A COUPLE MONTHS MAKING ADJUSTMENTS, ETC. AND BINGO, THE HULL IS DRY! I ENJOYED ANOTHER SEASON ON THE CHESAPEAKE BAY AND SOLD THE BOAT LAST SUMMER.
CALL SCOTT RICHMOND AT 616-308-2627 IF YOU WANT A STRAIGHT SHOOTER HANDLING YOUR UNFORTUNATE SITUATION.
PS   THE CULPRIT IN MY SITUATION WAS THE MANUFACTURER LEAVING OUT THE BEDDING MATERIAL NOR TIGHTENING THE ANCHOR ROPE LOCKER DRAIN PROPERLY.
TIP: CHECK ALL THRU HULL FITTINGS WHETHER ITS A NEW OR USED BOAT, YOU MIGHT SAVE YOURSELF A TIDY SUM.
WHY ARE YOU YELLING AT US?
(04-02-2019, 08:36 PM)Sans Peur Wrote: WHY ARE YOU YELLING AT US?
If you Google Dryboat, the "testimonial" above reads exactly like their advertisement on their website....
Interesting that this is their one and only post. And then they have the audacity to yell no less and didn't even introduce themselves!
How rude!
All caps greedy spammer troll
