Fuel transfer on 1993, 3100 open
Hi - I've been wondering if there are fuel valves on the fuel tanks to transfer fuel from one tank to the other?
john
I'm not aware of valves to transfer fuel from one tank to another. Normally there are a series of values that let you run one or both motors off of either tank or both.
To transfer fuel from one tank to another would require some type of a pump.
If you have diesels the return fuel lines can usually be cross fed back to a different tank. By closing the return line valve on the withdrawal tank and opening the return cross over, you will begin transferring fuel. Just be mindful of the tank level as once it reaches full you will be venting fuel over the side.
  3500 Open deck lift piston drmiagi11 6 1,215 11-20-2026, 10:03 AM
  38 - 43' Tiara Open Comparision ClayPlatt 8 8,864 10-27-2026, 02:44 PM
Last Post: tk17
  Access to the starboard fuel level gauge sensor? Tom Stewart 0 822 04-19-2026, 08:21 AM
Last Post: Tom Stewart
  2001 3500 open, diesel exhaust flanges? North Star 4 1,665 02-24-2026, 08:55 AM
Last Post: North Star
  1989 33' Tiara Open - Bedding Question jgaudet2 2 2,322 12-21-2025, 10:02 AM
Last Post: jgaudet2
