Tiara 3200 Gas or diesel?
Looking to purchase.  Boat broker tells me 90% were made with gas engines?  When I look at boats for sale, it seems the vast majority are offered with diesels.  Does anyone know? User comments one way or the other?
Gas 454's should provide plenty of power for a 3200. I would think on the great lakes, you'll find alot of gassers. In salt water, diesel might be popular for those looking for fuel economy and the need to run offshore. Just take your time and find the one you want with the options you want.
Good luck.
I owned a 1997 31 Open w/Crusader 454's and was more than pleased with their performance over the 10 years I owned the boat. Did everything we wanted. Traveled extensively as far south as the Chesapeake, east up to Boston, and north to Canada via Lake Champlain... Believe gas in a 32 would perform similar to the 31... Now own a 38 Open w/Cummin's Diesels and know there needed for this size/weight.  Always felt the limit for gas was the 35 Open which most likely performs better w/Diesels... M2C
We’ve had a Tiara 3200 with 8.1L Crusaders for three years now and love it. Originally looked for a boat with Diesels but went with this one after sea trial. Performance is outstanding and it handles well around the dock. Mileage and range is not as good as with Diesels but it is not an issue on the Great Lakes. Performance is great and the 8.1L Crusaders are known for durability. Depending on your need for extra range, I would consider a gas boat in this model.
(04-26-2019, 07:51 AM)TomRoss Wrote: Looking to purchase.  Boat broker tells me 90% were made with gas engines?  When I look at boats for sale, it seems the vast majority are offered with diesels.  Does anyone know? User comments one way or the other?
I’m a marine professional (BSc in Marine Engineering). IMHO, provided correctly sized engines are used a low 30’s sized boat will perform just as well with gas engines as with Diesel engines.
The reason bigger boats aren’t provided with gas engines is simple! Nobody builds gas engines large enough to power them!
The real difference are as follows:
1) Diesel is safer as a marine fuel than gas.
2) Diesel engines achieve max torque at significantly lower RPM’s.
3) All things being equal, Diesel engines will outlast gas engines.
Having said that, provided you keep in mind that you’re sitting on a Molotov cocktail and you’re going to be an average user (100 hours/year) you’ll be good with gas engines.
However, if you’re going to be stupid (e.g. replace a marine starter - explosion protected - with an automotive starter or neglect to properly maintain your engine room ventilation system) then you’re likely going to be a contender for the Darwin Award...
The 3200 was never supplied with 454 power only 8.1 as far as gas models go, and they are very popular in the great lakes. The boat has plenty of power with the 8.1s even fully loaded with fuel and 8 or 9 people easily hitting 35mph. Don't let anyone tell you diesel boats don't catch on fire because exhaust related fires on diesel boats happen more than they'll admit to.
I have a 2007 36' Open with 8.1 Crusaders and the power is more than enough.  Gas engines are a heck of a lot easier to work on than diesels.  Fuel economy is similar to diesel.
  [Tiara Sovran] Tiara 4400 PWC Lift on Swim Platform Feetwet 0 119 11-08-2026, 02:05 PM
Last Post: Feetwet
  38 - 43' Tiara Open Comparision ClayPlatt 8 8,864 10-27-2026, 02:44 PM
Last Post: tk17
  Bridge Clearance Tiara 43 LE with Radar rcparks@pacbell.net 0 676 03-31-2026, 03:54 PM
  2025 Tiara 43 LE rcparks@pacbell.net 0 691 03-29-2026, 04:13 PM
  2001 3500 open, diesel exhaust flanges? North Star 4 1,665 02-24-2026, 08:55 AM
Last Post: North Star
