Just splashed this past weekend and noticed a new noise coming from the port trans. The video linked below is an example of what I'm hearing when the throttle is at idle and the trans is in neutral. If the throttle is increased at all or if the transmission is put into gear, the sound goes away. Is this an issue with the damper plate or a larger issue? Any help/suggestions would be appreciated but I'm pretty sure I'm not moving the boat again until I have this figured out.
2002 3100 Open. 8.1L Crusaders, ZF Hurth Trans.
https://youtu.be/pJ71wbSoELo
