Tiara Open Porthole Windows Will Not Stay Up
This seems pretty simple, but I have 6 portholes/windows on my 2000 Tiara 3100 Open.  5 of the 6 windows will stay in the raised position when I open them.  One is a problem & flops down.  I am not sure if the acorn nuts on the problem window are original - they look a little different, but they are tight.  Suggestions?  Thanks in advance.
(05-13-2019, 02:01 PM)bruce@bigrivergroup.com Wrote: This seems pretty simple, but I have 6 portholes/windows on my 2000 Tiara 3100 Open.  5 of the 6 windows will stay in the raised position when I open them.  One is a problem & flops down.  I am not sure if the acorn nuts on the problem window are original - they look a little different, but they are tight.  Suggestions?  Thanks in advance.
There are two ways to keep such portholes open: a spring or a friction device. Check and replace as necessary.
I have taken them apart, & cannot find a spring or friction device.  Can you provide more detail?  Thanks.
The friction device might look like a plastic “bearing”. The friction might also be induced by putting the hinge under tension. You say you have taken them apart, were they identical other than the acorn nuts? If so, try using the acorn nuts of another porthole on this porthole. If that solves the problem then you have your answer.
  [Tiara Sovran] Porthole Screens robwhite433@yahoo.com 3 3,965 02-13-2024, 12:19 PM
Last Post: Narrowriver
  [Tiara Sovran] Stuck bathroom porthole Donaldjames 0 995 03-09-2023, 10:11 AM
Last Post: Donaldjames
  [Tiara Open] Porthole Locks Joeboch348 1 1,543 02-18-2023, 09:42 AM
  Wrong Porthole Gaskets? MC1600 6 5,358 04-11-2022, 10:30 AM
Last Post: MC1600
  Porthole Gaskets GeoDoc 17 12,673 03-14-2022, 07:37 PM
